Author Topic: opinion on S.C.I.'s float bowl gaskets (Honda CB350F)  (Read 893 times)
Offline Dynamo
« on: May 26, 2012, 06:20:55 PM »
Has anyone ever used these? http://www.siriusconinc.com/pro-detail.php?pid=&product_id=1506
I ordered 4 gasket kits from Honda and cleaned / replaced all of the rubber in my carburetors with the oem kits, HOWEVER when It came to using the float bowl gaskets from honda the o rings I got were longer than what was needed. I would have to cut / epoxy them to get them to fit. (something I want to avoid) and these "Fitted" gaskets from SCI any good?
1973 Honda CB350F
Re: opinion on S.C.I.'s float bowl gaskets (Honda CB350F)
« Reply #1 on: May 26, 2012, 08:22:35 PM »
I cut and superglued gaskets for my 350f bowls for years without any issues, but the SCI ones should be great if you feel the need...
Offline camelman
  • Man... Myth... Legend
« Reply #2 on: May 26, 2012, 11:55:55 PM »
I cut and glued mine in.  I use three bond, which is a liquid gasket.  It works great.  The SCI gaskets do seem too long.  When you cut them, try to taper the cut so that the matching ends create an overlapping taper fit.  Mine have been leak free for three years and 6000 miles.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
