OK, I'll try once more, but I'm sure others can explain better.
Imagine I start by setting my breakerpoints 1+4 at a dwell of exactly 49o. Then I set, by adjusting the baseplate, the timing static exactly, spot on the static F mark. When revved you'll see that full advance will be at the first of the two full advance marks (that are 3o apart btw, remember?).
Now I do it differently. I start by setting the breakerpoints 1+4 at a dwell of exactly 46o. Then I set the timing again static exactly, spot on the static F mark. When revved you'll see that full advance will be at the second of the two full advance marks. I leave it for native speakers to explain. But this happens with my 500. Don't ask me how, it happens. Ever asked yourself why there are no double F marks (static)? Well above you have your answer.
BTW only with genuine Honda parts. When I discovered this many years ago, I was impressed how precise these parts were designed.
