Author Topic: Add accelerator pump to a set of 550 PD carbs?  (Read 4498 times)
Offline Flying J
« on: May 30, 2012, 05:40:33 PM »
What do you think? Both my 750 and the 550 i owned had PD carbs. The carb bodies are basically the same. All the holes for the accelerator pump are on the 550 carb they just are not drilled out all the way. So i got to thinking. Could I finish drilling out the holes and put an accelerator pump on my 550 pd carbs? Is it worth it? I have all the parts to make the swap accept the bowl with the accelerator pump. Used a little heat and some pliers and got the parts out of the #4 carb. Here is the spray nozzle and plug as well as the inlet tube.
What are your thoughts?
Offline harisuluv
Re: Add accelerator pump to a set of 550 PD carbs?
« Reply #1 on: May 30, 2012, 06:44:04 PM »
I see what you're saying.  I guess it could be done, but the implementation I think would be a lot harder than the theoreticals.
Offline 1stgenxxx
« Reply #2 on: May 30, 2012, 07:08:22 PM »
If your carbs are tuned right....You shouldn't need one.
Offline Flying J
« Reply #3 on: May 30, 2012, 08:12:30 PM »
YEs you dont "need" them, but it would be an added benefit even if your carbs are tuned right. Also im not putting these on a stock motor.
« Reply #4 on: May 30, 2012, 10:34:30 PM »
I haven't looked at the two carb sets side by side.  But, it seems like the pump actuator might be the hard part.
Still, anything's doable with will, time, and money.
Offline Flying J
« Reply #5 on: May 30, 2012, 11:28:01 PM »
Right. The pump actuator mints to a hole on carb 2. The same hole is on the 550. The only difference may be the distance from there to the bowl. I'll take some pictures for comparison. Its crazy how similar these 2 are. I don't think it would cost much to convert. I would need a set of small drill bits and the #2 bowl with an accelerator pump.
Offline mrrch
« Reply #6 on: May 31, 2012, 07:18:42 AM »
Does the throttle shaft have the arm that pushes down on the accellerator pump shaft?
my build
Offline eastyork1977
  • Tuning and building in the Great White North
« Reply #7 on: May 31, 2012, 08:08:07 AM »
Accelerator pumps are usually found on 550F/750F models. Why not just get an F engine or carbs?
Could be a lot easier. I'd do that or get oversized jets.
'73 CB350G
'75 CB400F
'77 CB550K3 "Swayze"
'78 CB550K Stock
'78 CB750F2 Stock-ish
"take a peak." - Don Cherry
"If I can bounce a wrench off a tyre and it hits you, you're standing too close."
Offline Flying J
« Reply #8 on: May 31, 2012, 08:58:21 AM »
eastyork, welcome to the forum. Have a look around and learn a bit before you start giving advice. The 550 never came with an accelerator pump, K or F. THats why im looking at modifying one. Changing out the engine to an F model? ITs the same engine as the K.
Get oversized jets? Do you even know what an accelerator pump is or does? Tag along and learn something.
So, moving on. THe 750 and 550 carbs have the same body and could even be racked side by side if it were not for the throat diameters. Top bar and choke bar all line up.
To add the accelerator pump you need the linkage that pushes on the accelerator rod. seen here on the 750 carb.Its the thing that mounts in that small hole, right center of the picture.
It mounts to a hole. Same hole same spot on seen here on the 550 carb.
That is connected to the pull cable track which has some extra pieces. But I measured them both and they are the same width and the shaft is the same diameter so you can just swap the 750 pull cable track onto the 550.
750 on top
the 750 an550 have all the same holes. 550s just have not been drilled all the way. THe extra hole on the 550 carb on the top right is the hole for the accelerator pump shaft since this is carb #2
The tube that runs horizontal. this is the 750 #4 carb so it is a dead end.
550 not drilled out
750 this is where the little spray tube goes in and then a plug close off the hole.
This is the same hole on the 550. It alread is drilled out to fit the plug and just needs to be drilled further to push the spray tube in.
I have a set of Extra 550PD carbs on the way i think i will try this on. I do need the bowl from #2 on a 750 or 650 is anybody has one.
« Last Edit: May 31, 2012, 09:04:53 AM by ffJMoore »
Offline mrrch
« Reply #9 on: May 31, 2012, 10:48:52 AM »
All the workings are there, go at it and say you did it. I don't have a 550 but will be curious to find out the results in the end. I may have a spare #2 bowl (I'll try to remember to check tonight) You could always try member SOHC Digger as well.
my build
« Reply #10 on: May 31, 2012, 10:59:59 AM »
Are PD 50 carbs that hard to find?  (I haven't tried).
Offline lucky
« Reply #11 on: May 31, 2012, 11:10:33 AM »
Even if you did all that is needed then you would have to go back over all of your jetting again and you may never get the right combo.
A complete waste of time.
Only the 1977-78 models had that feature.
A ll of the other models 1969- 1976 did nit need that.
BTW do not forget the restrictor tubes that go inside the rubber hose connecting all of the spray jets.
Offline mrrch
« Reply #12 on: May 31, 2012, 11:18:43 AM »
Nothing wrong with experimentation, don't know the outcome until someone tries.
my build
Offline Flying J
« Reply #13 on: May 31, 2012, 11:24:04 AM »
I don't think a short spray of fuel when you open the throttle its going to throw off the jetting. I will also have a look in the tubes to see if restrictors are still in there. Should be they are the stock tubes.
Also even if it doesn't work it is any easy mod to reverse.
Offline Deltarider
« Reply #14 on: May 31, 2012, 12:05:00 PM »
Interesting project. I admire your initiative.
CB500K2-ED Excel black
« Reply #15 on: May 31, 2012, 12:14:51 PM »
Might just work. sounds like you've thought it through. I'm wondering why the carbs were cast with a provision for something not used. Maybe it got cancelled due to bean counters and cost cutting.
« Reply #16 on: May 31, 2012, 01:58:06 PM »
You will be able to greatly increase the pilot circuit air supply.
I once tweaked the air screws on 022a carbs for max idle speed and minimum exhaust gas hydrocarbons at each exhaust outlet.  Setting was outward about 5 turns.  Beautiful idle.  Completely awful throttle response as ANY twist made the engine wheeze and essentially shut off.  Accelerator pumps would have cured this, I'm certain.
I had to go back to factory air screw setting to be able to actually drive the bike.  The older carbs are actually quite piggy at idle.  Which is why they were phased out of production.  Simple and forgiving of untrained meddling. But, horribly inaccurate for providing exact engine needs.
Offline Lostboy Steve
« Reply #17 on: June 01, 2012, 10:19:41 AM »
Well, seeing as though I accidentally have a set of 77-78 750 pd's from a purchase on ebay, maybe I too should jump into this fire with my 77 550k. I don't know what the real benefit will be though.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline lucky
« Reply #18 on: June 01, 2012, 11:41:51 AM »
I am sure someone will jump and say DO IT.
They have all the fun of sitting back watching thee show.
Remember if you drill one hole wrong or something cracks or
breaks there goes a good carb body.
The stock 1969 carbs ran GREAT!! I was a dealership mechanic at that time, on these bikes. I know.
Offline Flying J
« Reply #19 on: June 01, 2012, 01:38:50 PM »
If you drill a hole wrong it won't matter. It may make the carb useless for the conversion but will not affect the function of the rest of the carb.
« Reply #20 on: June 03, 2012, 02:35:10 AM »
Geeze Lucky, if everyone bailed out at the thought of something going wrong we would all still be living in caves. Good project FFJ, this is the sort of stuff that peaks my interest in this forum, sometimes the most rewarding part of fettling anything is making something yourself, whether or not it is successful isn't really the point, its the satisfaction of using your mind and skill to do it yourself, continue on the road to discovery mate..... ;D ;)
Sometimes the journey is more important than the destination...
Offline Flying J
« Reply #21 on: June 12, 2012, 09:40:35 PM »
Well I picked up a spare set of PD carbs for this experiment as well as a #2 bowl for the accelerator pump. I also picked up the mill bits i need. They dont work well in my dril chuck so I'm waiting on some collets to come in the mail. Then I will try the bits out on some scrap to make sure they are the right diameter for all the different holes. After that i will practice on an old carb body. If all goes well Ill take apart my spare rack and go to town.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #22 on: July 04, 2013, 04:48:37 PM »
I am picking up this old thread on purpose because I am considering precisely this same modification.
I got a rack of 77 cb750 pd42a carbs basically for free with the accel pump on the #2 float bowl.
I have a 77 cb550k with its pd 46a carbs.
I have bored the barrels to 600cc total, put compression ratio should be no higher than 9.5:1.
I will be running one of Carpy's 4-1 pipes and (mostlikely) will use the stock airbox with a UNI or similar filter. I might consider adding some holes to the airbox.
I am thinking I'll start with a set of 120 mains (but I have 115, 110 and 105 mains standing by).
I have the #42 pilot/slow jets installed.
So... I wonder what happened to Flying J's project.  I've been a bit frustrated with the slow way my cb500 takes throttle from standstill when it's otherwise correctly tuned.  Once the juice is flowing, it does what it's supposed to do... and in fact, given the physics involved it's ALREADY doing what it's supposed to do, right? I just don't like it when I'm used to the RIGHT NOW WFO experience of modern bikes.
This could be an elegant (and basically free) solution that gets a small step closer to approximating that twist bang go feeling I've come to love.
What am I missing logic-wise here?
thanks
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline crazypj
  • I'm brill, me
« Reply #23 on: July 04, 2013, 04:51:30 PM »
 That's a first for me, never seen a 550 F1 or F2 with accelerator pump
« Reply #24 on: July 04, 2013, 04:58:26 PM »
Really?
