From totally empty to totally full, my 750 holds 3.5 quarts. With oil and everything else, higher than a cat's back, a person just can't help noticing how much oil an engine takes when you change the oil. I am a farmer, and my cat powered semi takes 15 gallons to bring the dipstick back to full, ouch that really hurts the wallet! Gordon, I have been changing oil longer than you, so what gives, do you have a pump stuck in a 55 gallon barrel of oil for all your changes? How can you not somewhere make a mental note of how much oil you are pouring in an engine, not for remembering, just an observation. Oil changing is made easier by doing the same engine over and over. An example is my wife's car, the manual calls for 3.6 quarts during a change, but it takes exactly 4 quarts to bring it back to full. People do need to know oil level in a 750 for convenience sake. Pour in the known amount, check the dipstick just to be assured, and your good to go. Why make an oil change into something where every time it takes multiple attempts to fill the crankcase because you go by the seat of your pants? Refilling a crankcase doesn't have to be as time consuming as filling a graduated chemistry cylinder. Sorry Gordon, but the man asked a fair question, why give a wisecrack answer? If you can't help the man, don't answer his post.
Justin
