Author Topic: Help with 72 cb750  (Read 1236 times)
Offline bikerbart
Help with 72 cb750
« on: June 01, 2012, 09:41:30 AM »
Anyone with an unmolested 72 ,I need pics of the electrical area behind the left sidecover,I have all the diagrams I need,but I want to see what the red wire connects to(fuse??)
Re: Help with 72 cb750
« Reply #1 on: June 01, 2012, 10:13:23 AM »
 I am swinging through my shop this afternoon,will snap a couple of pics in case no one else does.
Offline Lamp
« Reply #2 on: June 01, 2012, 11:16:28 AM »
You're right. The red wires with female spade connecters connect to each side of the fuse holder. On my bike there was a green wire with an eyelet that turned out to the ground for the stator. There should be a 6mm threaded for the ground wire.
1972 CB750K, with lots of F-model parts... SOLD
Offline bikerbart
« Reply #3 on: June 01, 2012, 11:56:42 AM »
thanks.I have the one red wire which i know goes to a 15A fuse,what connects to the other side of the fuse?Red/white?
« Reply #4 on: June 01, 2012, 02:02:13 PM »
Here's a couple of pics from a stock 72 750.Red to both sides of the fuse block and a total white wire is the turn flasher.  Eric
« Last Edit: June 01, 2012, 02:04:24 PM by ekpent »
Offline bikerbart
« Reply #5 on: June 01, 2012, 03:42:20 PM »
awesome.Thanks a lot.
