Have any successful SOHC4 racers used a "pod"? I thought they favored Velocity stacks. Perhaps I wasn't paying attention. ![Undecided :-\](http://forums.sohc4.net/Smileys/default/undecided.gif)
Just wondering...
They run the "filters"....I absolutely hate the word "pods"
That's probably an important distinction.
If someone is looking for a functional solution to a carburetor inlet, they want a filtered system.
If someone is looking for a style change without regard to function, then they want a POD.
Since this is an SOHC4 forum, I assumed we would talk about those, rather than anything that had a "racer" moniker associated with it.
But, from what I have learned so far, the G50 has a single cylinder, single carburetor, single filter, 500cc engine revving to 7500 RPM. I've no idea if the carb and intake velocities are comparable to what we see on the SOHC4 among the 4 carbs. But, that seems unlikely, to me as I sit in my chair typing this.
As I watched the Isle of Man video of the G50 matchless, I made a few observations. Before the start of the lap, I notice the rider had to constantly blip the throttle, presumably to keep the spark plugs clean. (This suggests the carbs were not tuned, or poorly tuned for a wide range of engine operation.)
During the lap, very seldom did the RPM dip below 6000 on a 7500 RPM red line engine.
This was no street bike. For an example of a race bike that used a pod type filter, it might be beneficial to note these limitations and ask if you want those characteristics on your daily driver.
At Bonnevile, again these are are flat out machines where the operators care little about engine operation outside of a very limited operational rpm band. (They do care about ingesting salt crystals.) So far, it seems the arguments all support using separate filters ONLY on specific purpose race machines where no other option is readily available.
Could the general populace be using individual filters to simply pose as a racer?
Regarding air boxes:
Anyone recall seeing air boxes on bikes before the SOHC4? I'm wondering if these were early "cusp of a trend" design examples.
ok, so we know that for ideal running on the street (in part throttle situations) we should have the carb rubbers and a plenum roughly about the same volume as the stock airbox.
I'll speculate, that the SOHC4 design is non-ideal, but rather an early compromise design to fit within the confines and operational limitations of the bike then in production at that time. I know the Cb550 Frame tubes directly interfere with that air plenum and the plenum was undoubtedly altered to fit. It's not easy to find pods that fit there, either. K&N doesn't even bother to make theirs fit.
So, why doesn't someone make a much better looking airbox? or even better a more functional airbox?
Because it is hard, requires knowledge outside of twisting a screwdriver and wrench, takes time and development money, the gains are in the 10% (or less) improvement margin, and doesn't fit within the "style wanna bees club" ideals.
I just don't think people are being creative enough in approaching this issue.
I agree. But, if you ARE creative, and get it working well, then the club will just point, laugh, and criticizes however it looks, and tell you that cheap pods look better. imo.
