Author Topic: There has to be a way.....??  (Read 1322 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« on: June 16, 2006, 09:00:02 AM »
There has to be a way to remove the shaft that holds the two carb lifter fingers
on the K! and later carb racks.  This is the shaft that rotates with the throttle
cable.  It seems to be pinned in the backing plate.  Removing all bolts and
screws doesn't free it.  The fingers are indexed in the shaft by woodruff (sp?)
keys but how is the shaft held in the plate?  ???
Pic of the guilty party follows...
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline dusterdude
Re: There has to be a way.....??
« Reply #1 on: June 16, 2006, 01:53:51 PM »
hmmmm
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #2 on: June 16, 2006, 02:05:17 PM »
There is probably rust holding the keys to the rod and leavers.  I broke one of the lifting arms on my 550K trying to spread the slit a little bit.  Get a good penetrating oil and lots of patience.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #3 on: June 16, 2006, 04:05:08 PM »
I have that very item apart for cleanup less than a month ago.
You've already removed the bolts. The only thing left is the two half moon key at each end of the shaft...
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline techy5025
« Reply #4 on: June 16, 2006, 04:53:33 PM »
The shaft will move sideways in the backing plate about an
eight inch in either direction....and the finger jobbies are not
hitting anything when it freezes.....
More inspection later....thanks for the help.
Jim
2003 CBR600F4I
Offline techy5025
« Reply #5 on: June 16, 2006, 07:23:42 PM »
Found it!  There was one bolt/screw broken off flush with the casting. After
drilling it out and some coaxing the shaft came out.
Thanks for the help.  On to the next problem.  ::)
Jim
2003 CBR600F4I
