At this point, you might as well try a torch, and a really fine chisel, but you know what.. really, you just need to pony up some $ and do what you gotta do. Pistons are cheap, rings are cheap. You're not gonna find usable transportation for anywhere near the $100 investment you'd make fixing it right, or even semi-right. If the bore is uniform and in spec, go buy a piston.
