Author Topic: Better gas mileage on the 550  (Read 4729 times)
Offline kayaker43
Re: Better gas mileage on the 550
« Reply #25 on: June 07, 2012, 05:46:24 PM »
That's the way I understood it too,.. better atomization. It probably did lean the mixture but less of it went out the exhaust unburned. More of it contributed to power but less fuel was used.
Its one of those things that works first then gets explained later.
« Reply #26 on: June 07, 2012, 06:05:07 PM »
TwoTired, I think the idea was that it atomized the fuel better (from what I understand reading this thread), so likely burning more of the fuel that is already there, meaning you would need to use less fuel for the same amount of power.
How is this NOT saying the mixture is being leaned?   Less fuel and more air, makes a leaner air/fuel ratio.
Sorry, I just don't believe in magic.   ;D
If you are getting better economy with the same mechanical volumetric efficiency, you must be leaning the mixture.  I'm not saying that's universally bad.  I'm saying the carbs are dumb and are usually set so they can run without causing damage in any part of the world.  If you fine tune (make leaner)  for your current barometric pressure, temperature, and humidity, you may encounter another set of conditions later to make it richer or leaner.  The carbs will not automatically adjust for this.  They deliver based on set physics.
I'm just trying to identify the risks before diving into the pool.
In engineering for other people, a test case of one is always inconclusive.  Particularly if one has no idea of what was being done to make the test case.
Offline Tews19
  • I am no
« Reply #27 on: June 07, 2012, 06:27:20 PM »
Guys, I'm sorry if I upset any with the thread. I was lookin to get crazy MPG and tinker with the bike. I lie the aspect of working on the bike and having success with the effort put forth. Simply stated, I wanted to try new things and was curious if there was any success with this application
1970 Honda CB750 survivor.
« Reply #28 on: June 07, 2012, 07:02:53 PM »
Your nothing but a trouble maker Nick   ;D
Offline Tews19
  • I am no
« Reply #29 on: June 07, 2012, 07:18:42 PM »
My feelings are hurt :(
« Reply #30 on: June 07, 2012, 11:54:16 PM »
This tube mixes air with the fuel coming up around the needle and makes it sorta foamy (or emulsified) Apparently it atomizes better when it enters the airstream as a foam? The main jet and needle/needlejet do the fuel metering. somewhere there’s an air jet feeding the emulsifier area.
I wonder if there's a favourite way to put them in again. Are those little holes supposed to face head and rear or left and right. I suppose orientation doesn't matter at all, but who knows.
I'd like to see what a GPz 550 emulsion tube looks like. Any pics?
« Reply #31 on: June 08, 2012, 12:57:08 AM »
its a 500 tank delta,,the sad fact is if you have horses you have to feed them.
« Reply #32 on: June 08, 2012, 03:34:16 AM »
i get 200 klm before reserve,sometimes 220,
I say, that's not a bad mileage at all. I only managed that on old Greek countryroads. Overhere I have to switch to reserve after 175kms.
« Reply #33 on: June 08, 2012, 03:54:45 AM »
i dont spare mine,,or try for fuel economy,,we have decent proper petrol here aswell,which helps,i mostly use the 95,,we have also 98,,and 91 with ethanol for the peasants and gypsies.
Offline Tews19
  • I am no
« Reply #34 on: June 08, 2012, 05:54:06 AM »
HILARIOUS!
