http://forums.sohc4.net/index.php?topic=4089.0"The popping on decel is likely from accumulated fuel in the exhaust system lighting off.
Leaks in the exhaust system can provide oxygen to enable the fuel to ignite.
If all the slides don't close evenly some cylinders are getting more fuel than others and that is being passed, unburned into the exhaust. (Carb sync.)
Leaning the idle mixture (turn screws out), should help abate the fuel buildup in the exhaust when the slides are closed.
You might have to address all three, above.
Cheers,"
That was a post from TT in the above thread.
"So after playing with it for a while, I found that it was a lean condition that was causing the pop. Mixture screws (on airbox side) are now out about 3/8 turn (manual says 1) and the popping has almost completely gone away. Plugs are brown at either setting but the popping is gone. Anecdotally, the engine and the oil tank seem to run a bit cooler as well.
I don't get it - the theory of rich mixure/unburnt fuel in exhaust/pops in the pipes sounds right, but not in this case. Maybe popping could be either too lean or too rich? Ordered a carb synch set, so after I synch perfectly, I'll see how far I can get the screws out before the popping starts again.
For everybody who likes the popping - I don't mind it either, but I ride every day in New York City - pretty close quarters to be making startling noises - especially on my way to work through the Holland Tunnel with the homeland security guys posted at the entrance. They're trained not to like sharp popping noises. "
That was his resolution to the popping.
