Author Topic: Engine leaking oil..  (Read 3952 times)
Offline messeduptriple
« on: June 08, 2012, 03:47:54 PM »
I finally got the 550 to run perfect.   Idles well, and sounds great. I plugged the tach that was leaking oil with an aftermarket spike plug from ebay. That is no longer leaking but I still have a good amount of oil coming out somewhere from the upper front engine. When it idles it doesn't leak but when I hop on the highway it's leaking, I can't seem to see where though.  I stopped and looked but seems to be in the front somewhere.  I cant see any cracks  major and have no idea where to go from here.  How can I check now?  Should I use some engine oil sealer  from fleet farm??  Any help would be great.
Sent from my MB855 using Tapatalk 2
Re: Engine leaking oil..
« Reply #1 on: June 08, 2012, 03:50:31 PM »
« Reply #2 on: June 08, 2012, 03:54:22 PM »
Offline goldarrow
  • one day, i'll be an
« Reply #3 on: June 08, 2012, 04:18:37 PM »
I don't have whole lot of expertise on this but from what I have read from other posts : top end rubber seals and gaskets may need to be inspected or replaced, or live with it if the leaks are minimal. Check oil level regularly though.  Someone please chime in if I'm wrong.  Hope this helps.
CB550 K0
bollingball
« Reply #4 on: June 08, 2012, 04:45:16 PM »
Engine oil sealer. I wonder what that would do to your clutch want to take a guess?
Ken
« Reply #5 on: June 08, 2012, 04:49:01 PM »
I just cant seem to find out where all the oil is coming from.
« Reply #6 on: June 08, 2012, 05:04:01 PM »
Some guys will clean and degrease the engine and then when dry sprinke baby or talcum powder or such around on the engine.Start it up. When the oil first starts to leak the powder gets wet making the spot easier to identify. May be worth a shot.Won't work going down the highway though.
« Last Edit: June 08, 2012, 05:05:33 PM by ekpent »
Offline LesterPiglet
  • 1977 CB550F2
« Reply #7 on: June 08, 2012, 05:05:22 PM »
Clean and degrease the engine. Cover the engine with talcum powder. Take it for a short spin. This should show up the leaks.
Don't forget to wear a funny hat.  :)
ekpent beat me to it.
Offline DJ_AX
« Reply #8 on: June 08, 2012, 05:08:40 PM »
foot powder in an aerosol can works great
Offline matt mattison
« Reply #9 on: June 08, 2012, 05:15:37 PM »
Did you make sure all the bolts on top of the engine are tight? Don't over tighten them though, the cast aluminum could crack. Try to go by the torque specs in your manual. It's worth a shot.
1975 CB550F
2011 MV Agusta Brutale 1090RR
« Reply #10 on: June 08, 2012, 05:31:03 PM »
I looked after cleaning a bit and found this ...its chipped ..could this be the leak?
  • 1977 CB550F2
« Reply #11 on: June 08, 2012, 05:38:28 PM »
If you are referring to the gap at the base gasket that is  normal. From your previous pictures the leak looks higher up than that. I'd be looking up the top first.  Do the talc test.
I just reread. Check your latest tach cap and also the tappet covers. I found one of mine leaking the other day.
« Last Edit: June 08, 2012, 05:41:38 PM by LesterPiglet »
« Reply #12 on: June 08, 2012, 05:45:50 PM »
Nevermind ...cant get the bike to start anymore ... lol ... fml.
Offline goldarrow
« Reply #13 on: June 08, 2012, 05:46:52 PM »
That's the gap for screwdriver to pry off cylinder...not chipped
CB550 K0
« Reply #14 on: June 08, 2012, 05:49:49 PM »
I tried to idle it ..reving  it and waiting for oil leak ..then decided to spin around the house and park and stopped the bike..couldn't get in neutral  so stopped the bike and turned off ..hit neutral now doesn't want to start..sounds like its dead..getting that clickn  noise.
  • 1977 CB550F2
« Reply #15 on: June 08, 2012, 05:51:00 PM »
Put the battery on charge for a few hours and have some beer.
« Reply #16 on: June 08, 2012, 05:51:52 PM »
* it was only smokn  lightly from the right header ...any info on why?  I used the heat gun ray and they were all in same temp ..not sure wtf is going on. Im mentally exhausted from this bike now...getting so frustrated ..if not one thing its another.  Maybe I shouldn't have done this project.
  • 1977 CB550F2
« Reply #17 on: June 08, 2012, 05:54:13 PM »
Burning oil, say from an oil leak, gives off smoke.  ;)
So is there oil in the exhaust port then?
Re: Re: Engine leaking oil..
« Reply #18 on: June 08, 2012, 06:42:56 PM »
I dont know ...should I pull the exhaust off??  I'm gonna try that powder deal tmrw.
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #19 on: June 08, 2012, 07:23:30 PM »
If it's not seeping from the valve cover, then it's probably leaking past the rubber pucks that seal the head bolt holes under the valve cover. The oil leaks down and flows into the spark plug wells. From there, the wind distributes it all over the top end. Tightening won't stop it. You'll need to purchase 6 new pucks, and replace them. Make sure the recesses they seat in are clean and dry, and use no sealer of any kind on the pucks. As long as you'll have the valve cover off, you may as well re-torque the head. Don't neglect to replace the valve cover and breather cover seals.
« Last Edit: June 08, 2012, 07:25:35 PM by chickenman_26 »
MCN DTF
Offline fergie
« Reply #20 on: June 08, 2012, 07:47:47 PM »
Most likely the head gasket/ rubber pucks. If the bike is smoking from one of the pipes you probably have a ring job ahead of you. The head gasket /rubbers pucks commonly leak one old honda fours. sounds like you need to do a engine tear down.
The most interesting man in the world
« Reply #21 on: June 09, 2012, 03:30:27 AM »
Oh
« Reply #22 on: June 09, 2012, 03:37:54 AM »
this may sound stupid but what are pucks? ??
Offline Mcwilliams570
« Reply #23 on: June 09, 2012, 05:23:54 AM »
The round black things in the pic are pucks...
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
« Reply #24 on: June 09, 2012, 05:38:41 AM »
Thanks.  Do I need to yank the whole engine out? And how do these go bad? I bought it and it didn't do this ...now its doing this leaking.
