here's the spots I had tacked off. Waste of $$ on a street bike. Wished i'd had it done on my racer, so I'm doing it now:
headstock gusset to downtube, note, do not close off the bottom of the upsidedown U:
Removable gusset for my old sytyle APE frame kit:
HD front mount, douybled up with the case guard bracket:
All motormounts were increased in size and bored to fit bolts tighter, bolts made to fit, mostly from stainllss stock. Rear top rail gusset (slightly too big)
double sided rear motor mount made by Rob Voxonda
swingarm gusset (too small)
other welding included moved and permanent rear pegs, fork dampener mount, pad on base of sidestand.
Removed and replaced swiingarm bosses (long story)
I took my cues on the frame stuff from racers here and from Tony Foale frame guru. He says often with old Jap bikes the frame is more important to shore up than the swingarm.
