Logo merchandise is available at the SOHC/4 Shop
I had a flat the other day, tube type tire... there is a deck screw in it, do I replace the tire and tube? or use a plug/patch in the tire and just replace the tube...any thoughts?
The question is why patch it? It is a fairly small hole. The tube holds the air anyway. When you patch tubed tire you create a high spot inside the tire that the new tube can rub on it.
