Author Topic: Need help with CB650SC carb joint set  (Read 1053 times)
Offline dpionk
« on: June 15, 2012, 04:44:48 PM »
So I took my carbs apart on my 82 nighthawk and in the process the rubber T joints that link 1&2 and 3&4 fell apart to nothing.  I put just pieces of tube between them but it seems the bike does not like to run like that.  does anyone know what i can do with replacing these?  I can order them but just for the little rubber T theyre like $40 each.. WTF.
Offline onepieceatatime
Re: Need help with CB650SC carb joint set
« Reply #1 on: June 15, 2012, 07:31:30 PM »
Here is a thread about it on the 650 forum.
http://www.hondacb650.com/viewtopic.php?f=4&t=5890
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline tomkimberly
« Reply #2 on: June 15, 2012, 10:58:32 PM »
You said tee joint. Did you just connect the ports to the carbs and forgot the tee portion?
Tom
Offline dpionk
« Reply #3 on: June 16, 2012, 08:50:55 AM »
Thanks one piece I tried searching for and couldn't find what someone had called them. Very helpful.
Tom, well i figured it was worth a shot just linking them but finding out that it needs that vent.  Seems like this is used for idling, because the bike wont do it with them just solely tied together with no vent.
