Author Topic: 1978 honda cb750k carb rebuild help  (Read 1194 times)
Offline drmeloh
« on: June 16, 2012, 05:26:11 PM »
im going to rebuild the carbs on my bike, i have single pod filters on them and i found out that i have to adjust the Main jet #120, idle jets #42 and  one turn out on the mixture screw, also the i have to add shims to the needle. BUT do the pilot jet and main jet need anything in order for the carbs to get a good mix ratio of gas/air?
Re: 1978 honda cb750k carb rebuild help
« Reply #1 on: June 16, 2012, 05:51:24 PM »
You can't adjust the jets
Offline drmeloh
« Reply #2 on: June 16, 2012, 05:58:19 PM »
so they just need to be cleaned and put back the way they were?
Offline lucky
« Reply #3 on: June 16, 2012, 05:58:34 PM »
Language problem Stev-O.
"Im going to rebuild the carbs on my bike, i have single pod filters on them and i found out that i have to adjust the Main jet #120, idle jets #42 and  one turn out on the mixture screw, also the i have to add shims to the needle. BUT do the pilot jet and main jet need anything in order for the carbs to get a good mix ratio of gas/air?"
Yes that is right. A main jet is just a solid piece of brass with a hole in it. There is no adjustment.
To get the right air/gas mixture you will need to put washers under the slide needle .
The project may be too difficult for your skill level.
I think you should put the stock air filter back on the bike.
4 into 1 MAC exhaust no muffler.
Main jets #120mm
Idle jets #42mm
Needle stock. non adjustable.
Mixture 1 turn out.
After you do that you need to sync the carbs and it will all work very well with that exhaust.
« Last Edit: June 16, 2012, 06:04:38 PM by lucky »
« Reply #4 on: June 16, 2012, 05:59:37 PM »
Yeah, guess I don't speak California?!
« Reply #5 on: June 16, 2012, 06:02:00 PM »
First, do you know what size jets you have? If they are the wrong size, you can change them. And yes, they need to be very clean to work properly.
Offline lucky
« Reply #6 on: June 16, 2012, 06:07:21 PM »
The OP has not reported in on the accelerator pump system condition and function at all.
I explained it and how to check it in detail. no response on that yet.
Offline lucky
« Reply #7 on: June 17, 2012, 10:43:03 AM »
Hope we hear back from Drmeloh. Otherwise what a waste of time eh? :)
Offline drmeloh
« Reply #8 on: June 17, 2012, 07:26:30 PM »
ok everything you guys said sounds good.
i dont know what is the size of the jets, i havent touched the carbs at all. im trying to collect as many info as i can first so then i can manage to do it properly.
Offline harisuluv
« Reply #9 on: June 17, 2012, 08:08:01 PM »
Ok well, first collect the info on the carbs you want rebuilt  ;)
« Reply #10 on: June 17, 2012, 08:30:41 PM »
Send your carbs to Haris!
Offline drmeloh
« Reply #11 on: June 17, 2012, 08:42:31 PM »
well i check the manuel and the main jet is #120 and slow jet is #40.
float height should be 26mm.
im sure thats what they are, the previous owner said he cleaned the carbs but didnt say he changed anything.
« Reply #12 on: June 17, 2012, 08:46:38 PM »
Don't ever believe what the PO tells you!
