Author Topic: Valve spring shims - 750 k5  (Read 782 times)
Offline Z-MO
« on: June 17, 2012, 03:59:41 PM »
My new valve spring kit came with a set of shims.  There were no shims when I removed the old springs.  Do I need to install these?  If so, where?  Would the go below the spring seats?  Thanks
'75 CB750 Chop
'72 CB750 Cafe
Re: Valve spring shims - 750 k5
« Reply #1 on: June 17, 2012, 06:43:34 PM »
What is your installed height? They would go below the spring base. Those are .060 thick....I use different ones that support the base better. I would....in general...say do not use them but is depends on the cam, installed height etc etc.
« Last Edit: June 17, 2012, 06:46:34 PM by MRieck »
