Mine does the same......will not cruise at 30.......................Hard as heck to get it to idle on start up, have to keep flipping the throttle, to keep it running.Scribed......................
Wood is good
My bike does the stuttering when cruising, but my emulsion tubes are clean. Should i grab some new ones, or would it make a difference since all holes are clean?
After two years of fighting with my '73 Cb750 I've finally solved nearly all of my problems with one very simple, very cheap part. I'm super psyched to have finally fixed my bike, but upset at the amount of money I spent in the process........And the answer to all my problems was....Needle jets!Not the needles, not the main jets, not the pilot jets, and nothing to do with the idle circuit. I'm talking about the little press-in tube that the needle slides into in the bottom of the throat of the carb. These little jets don't come with many of the rebuild kits sold online, but completely changed my bike. I found cheap rebuild kits on the rusty riders website and included this part. This is literally the only part in the fuel system I did not replace aside from the carb bodies themselves. Don't believe that all 750s just hesitate a little bit off idle. My bike is 100% smooth now. All of my air screws are finally all at the same setting. I used to have them all over the place from 1 turn to 3 turns out just to get it to run. If you are having any of the problems I was having, then I strongly suggest replacing your needle jets. Maybe it will save you some time, money and frustration. Cheers!
How did you measure the play in the slides?IW
Quote from: iron_worker on June 19, 2012, 01:09:09 PMHow did you measure the play in the slides?IWFeeler gauge.
This is not a pod threadThis is not a #$%* on my vacuum gauges threadThis is a help or GTFO thread.
Quote from: longshanks on June 19, 2012, 02:32:08 PMQuote from: iron_worker on June 19, 2012, 01:09:09 PMHow did you measure the play in the slides?IWFeeler gauge.How would you get a flat thickness gauge between the slide and its cylinder wall?Where would you find specifications for that?It is not like a engine piston and cylinder where the piston is traveling thousands of feet and there is a lot of wear. Was there wear marks on the piston ?Even on dirt bikes in the desert I never heard of anyone measuring the carb piston slide clearances.Besides the cover on the top of the carb has a gasket to seal that area anyway.How would it make a difference?I have never see specifications for that even on car engines with slide carbs like SU's.
