1974 cb750
So my battery had been dying fairly quick over the past couple weeks. So i figured it was just time for a new battery (havnt replaced since i owned the bike). I had just been kickstarting it as there wasnt enough juice for the starter to work. After I changed the oil today i let the bike idle for about 3 or 4 minutes and then it died. I can fire it back up, but it wont idle. If i keep it reving above 2k rpm it will run, but if i let it drop to idle it dies. Is this because letting it idle for too long drained my already dying battery? Or do i have some other problem as well. Im going to get a new battery tomorrow and see what that does. Could my dying battery be due to a bad alternator? Or is this typical behavior at the end of a battery's life?
thanks gang
CJ
