gday franky,thats a lot of the head,,was it needed?,the valves with a stock cam are miles away from the pistons,,i dont think even with a lot removed from the head surface the valves are hitting the pistons,,with the head "shaved" or "planed" or "milled"itll sit lower and you might not be able to tighten the cam chain enough?with all the plugs removed and the engine hot and that tappet cover removed,rotate the engine over and again with the kick start by hand,,at the same time have a finger on the tappet,,try and feel if the valve hits the piston,you might feel a thud compared to the others?,also,,rotate that cylinder and watch the valves open and close,stop the engine at the point where both the inlet and exhaust are both open at the same amount,,now try and open the inlet further,itll be hard but you might be able to rig up a lever of a sort,,the valves are at their closest to the piston in this position,if you can push the valve down it clears ok,,you have great pressure of the dual springs to over come though,,engines are dummy assembled with very soft springs for this purpose,you have the standard flat topped pistons?
