Why would you know that mate, most guys here wouldn't? Anyway, yep, the F2/3 forks have 35mm tubes, so they'll fit your triples, which will have the same spacing as CB750 triples, so the axle from your wheel will be the same too.
You'll need to work out what caliper/disc combo's you're gonna use, the CB750/500/550 etc discs are big heavy baastards and 10mm thick, so may be too thick for the Brembo (or whatever) calipers. You might need to locate some thinner discs with the right offset to suit, and you'll probably need to make up new axle spacers.
Another problem that you're gonna have is spacing the discs out from the wheel so the back of the calipers don't hit the spokes. Brembo's (and every other opposed piston calipers) are much wider than our single piston calipers, so will definitely hit your spokes if you don't move the discs away from them.
As you can see from the pics of Brent Waller's beautiful 550 it's do-able, but will involve some engineering, and a little head scratching. The GL forks (and triples) make it much easier. Cheers, Terry.
