Author Topic: 73 500... Bogged down, now won't start...  (Read 950 times)
Offline Elpresidente
« on: June 23, 2012, 09:32:40 AM »
Ran good, bogged down near the gas station... Still has gas in it, won't start unless I use full choke... Then sounds like ass and dies minute I remove choke.
Any ideas?
'73 CB500
'12 Triumph Thruxton
Offline LesterPiglet
  • 1977 CB550F2
Re: 73 500... Bogged down, now won't start...
« Reply #1 on: June 23, 2012, 09:53:08 AM »
Check the contents of your float bowls for crap. You maybe have dirt in the fuel.
« Reply #2 on: June 23, 2012, 09:55:40 AM »
It's low on gas, help if I put fresh in it?  I'm couple miles away from home... Lol.
'73 CB500
  • 1977 CB550F2
« Reply #3 on: June 23, 2012, 10:10:30 AM »
If it's low then you may have sucked some crap in. Put more gas in so you don't use the reserve setting. Try and get home and clean that tank and carbs.
Online dave500
« Reply #4 on: June 23, 2012, 01:39:19 PM »
tried reserve?
« Reply #5 on: June 23, 2012, 02:00:29 PM »
It was on reserve... But I'm still a dumbass, put gas in it and it was good to go.  Ran out of gas at a gas station (and I was trying to run it out of gas.. Gotta play with the petcock again and decided gas station was good because I needed to put some air in the tires anyway)
Not my brightest moment, but I had sloshed it around and thought I had plenty to get there and back... And had sloshed what was in it after it died and still thought I was good.
Live and learn.
'73 CB500
Offline lucky
« Reply #6 on: June 23, 2012, 02:10:21 PM »
I do not like running any motorcycle on reserve unless it is an emergency because
There can be dirt and moisture that has collected in the bottom of the tank.
Then you may end up cleaning the carbs.
« Reply #7 on: June 24, 2012, 10:02:07 AM »
Yeah, I really shouldn't... tank is not pristine and like you said... just asking for more carb issues.  I get this petcock issue sorted and never on reserve again.   ;)
'73 CB500
