I didn't want to stink up the "What did you do to your bike today" thread anymore with my carb problems, so I'm making this thread.
Bike is a 1973 CB500K2.
Back story: Carbs were pissing fuel out from between the bowl and carb base on number 3 and 4. So, I ordered four Keyster rebuild kits from Jerry's Cycle.
Took all four carbs off the rack and dipped them, cleaned them up good, put everything back together (set float height at 22mm) and get everything back on the bike. Turn the petcock on, no leaks.
Fire it up, carb #3 is dripping every 5 seconds or so between the bowl and carb. Take it for a ride up the road and back, now it's leaking out of 1, 2, and, 3 between the carb base and bowl.
Via another thread I've been told there's too much gas collecting in my bowls which I obviously agree with. Should I set my floats higher than what's recommended? Also, there is no gas coming out of the overflow tubes so I'm going to have to find out why.
Any help is appreciated, she's running great other than this problem, and is currently my only bike so I'm jonesing to get some seat time in.
Thanks guys.
