Author Topic: Coating inside of points cover on 76 550  (Read 4447 times)
Offline CapeCafe
« on: June 25, 2012, 07:16:39 AM »
I was hoping someone could tell me what Honda coats the inside of the points cover with on a 550?  I took mine off to fix a couple small dents and remove a bunch of surface rust and the solvent also removed the coating inside the cover.  Is there a reason to paint/coat it ?  Thanks.
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
Offline xsmooth69x
Re: Coating inside of points cover on 76 550
« Reply #1 on: June 25, 2012, 10:14:42 AM »
i dont think there is a reason too. other than you just have to make a gasket for the points cover unless u have one
1975 CB550 (FINISHED?!?!?)
Offline CapeCafe
« Reply #2 on: June 25, 2012, 10:30:43 AM »
Thanks for the response.  I do have a new gasket.  I was curious since all the photos I've seen of stock points covers have that grey coating on the inside of the cover.
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
Offline Fritz
« Reply #3 on: June 25, 2012, 10:48:57 AM »
There must be a reason, otherwise Honda wouldn't have bothered to do it.
I can only guess. Maybe it's restricting condensation to areas where it cannot disturb the points...
1976 CB550F
Offline Sniper X
  • Resistance is not futile, it is voltage devided by current.
« Reply #4 on: June 25, 2012, 10:51:30 AM »
I heard it was to keep the spark from the points from grounding out on the steel cover...I say something like JB weld since that is and was what everyone used in the far past!
1973 CB350 Four, 1969 CL350 Scrambler (2) 1985 BMW R80RT.
Offline CapeCafe
« Reply #5 on: June 25, 2012, 12:16:04 PM »
Sniper- That sure seems to make sense.  i'll pick up some JB Weld and coat it.  Regardless it can't hurt.  It definently was some type of thick rubber like coating originally on the inside.  Thanks
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
« Reply #6 on: June 25, 2012, 01:43:55 PM »
I used to have a cb360 with an aftermarket finned points cover.  There was no coating on the inside and you had to be real careful about how you arranged the wires inside or it would ground/short and cause running problems.  So yeah, that could make sense about the coating.
Offline lucky
« Reply #7 on: June 25, 2012, 02:05:05 PM »
There is a reason for the special paint inside the points cover.
In manufacturing they do not add ANY process or part unless there is a reason because it costs money and time.
The special paint is to prevent a spark from the condensers or points from grounding on the inside of the cover if there is condensation. It also quiets the noise made by the points.
Offline CapeCafe
« Reply #8 on: June 25, 2012, 04:44:18 PM »
Looks like I'll be adding a little Rhino Liner to the inside of my points cover.  Thanks for all the help
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
Offline phil71
« Reply #9 on: June 25, 2012, 04:48:00 PM »
what about undercoating?  Also, does anyone make a rubber gasket for that cover, instead of that cork deal?
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #10 on: June 25, 2012, 08:04:08 PM »
The cork gasket is essential for points to function properly and I would use nothing else.  Modern electronic ignitions may benefit from neoprene seals.  I always thought the coating on the inside of the point covers was to dull the sound of the points clicking together.  We are not riding Harleys which create mega decibels of sound.  Our little machines are designed to be quiet and points click could have been a serious issue for Honda engineers.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline phil71
« Reply #11 on: June 25, 2012, 11:58:33 PM »
The cork gasket is essential ? C'mon .. Why?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #12 on: June 26, 2012, 12:34:46 AM »
I would say it's for sound deadening as well as electrical insulation. That pressed steel would act like an amplifier.
« Reply #13 on: June 26, 2012, 12:39:00 AM »
the points are a fair way away from the cover,i doubt a spark would arc that far,the base plate itself is very close to the points anyway.
  • 1977 CB550F2
« Reply #14 on: June 26, 2012, 12:41:25 AM »
Maybe for in the case of an accident. How many CB's have you seen with that cover bashed in?
« Reply #15 on: June 26, 2012, 01:18:52 AM »
The cork gaskets are crap.  They are one time use only and even new ones leak if "pre-shrunk" from too much self time.  I make neoprene gaskets for all my SOHC4s.  They are reusable, and keep water from seeping into the points cavity and fouling the points in the rain.  I made the first one in the early eighties, and it still serves to this day.
I don't really know for sure what function the internal cover coating performs.  Anti-condensation seems a good bet, as there is a "drain hole" at the bottom which would let the chamber "breathe" in outside humidified air.   Then during cool down...
I think I'll keep that coating.
Offline lucky
« Reply #16 on: June 26, 2012, 04:52:11 AM »
There is a reason for that cork seal.
The points cover gets removed often so do not put gasket cement of any kind on it.
Just rub a light coat of Vasaline on ONE side and leave that cork gasket stuck to the points cover. with a little Gaskacinch if it is not already stuck on the cover.
You want the cork gasket stuck to the cover NOT the engine.
Offline Steve_K
« Reply #17 on: June 26, 2012, 03:52:36 PM »
From what I have read, I may need to coat the inside of the points cover.  I am making one out of billet aluminum and that never came to mind.  I will have to mull over some the reasons stated, because none of that occurred to me.  When timing my bike, I never noticed the points making noise that I could hear.  Except when my condesors went bad and that was with cover off.
Need more info.   I thought the coating was cheaper than chrome, but that doesn't make sense, cost wise.
Steve
Steve_K
« Reply #18 on: June 27, 2012, 12:18:19 AM »
run a suitable bead of silicon around the covers gasket area,,let it set,,after cleaning the surface of course.
Offline DJ_AX
« Reply #19 on: June 27, 2012, 01:11:14 AM »
Hmmm... I wonder if an old inner tube cut just right would work?
  • 1977 CB550F2
« Reply #20 on: June 27, 2012, 02:01:17 AM »
Seems like an awful lot of trouble when you can just run some silicone around it.
« Reply #21 on: June 27, 2012, 02:14:59 AM »
you could find two off cuts off steel pipe,one the same as the outer and one the same as the inner diameter of the cover,,then grind them into large wad cutters and punch out a perfect gasket from an old inner tube,,or try scissors or find a big o ring or just use silicon,neatly with some finnesse.
Offline SohRon
« Reply #22 on: June 27, 2012, 05:33:35 AM »
Sooo, you gonna tell us all how to do it or what?  :D
Offline Gman
« Reply #23 on: June 27, 2012, 08:59:09 AM »
+1
I was just about to ask the same thing - any pointers would be appreciated to avoid reinventing the wheel, so to speak.
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline Gman
« Reply #24 on: June 27, 2012, 09:02:05 AM »
Nevermind-  just searched for it and found it.  Seems straightforward...
Tx,
G
'76 CB550K
