Author Topic: Gas tank builds pressure (solved: had to drill gas gap)  (Read 3012 times)
Offline fmctm1sw
« on: June 25, 2012, 11:49:12 AM »
As I prepare for the shakedown run to DMV on my 650, I notice the tank is building up pressure when the cap is on.  I have a NOS cap from a member here.  I dug around and found this thread:  http://forums.sohc4.net/index.php?topic=57700.0 that describes the vent passage as "next to those tabs."  I don't understand where that is.  I do have a small hole out towards the end of the cap.  I blew compressed air through it, no change...  Any ideas?
« Last Edit: June 25, 2012, 05:00:57 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Old Scrambler
Re: Gas tank builds pressure
« Reply #1 on: June 25, 2012, 01:53:04 PM »
Clean the vent.......pipe-cleaner and gas......Check your lid gasket.......it may be too wide and is blocking vent when closed..........and don't park in the sun 8)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline fmctm1sw
« Reply #2 on: June 25, 2012, 03:56:24 PM »
 ??? ???  I dug up my old gas cap, thought I had thrown it away.  Notice the difference?  My old one has a vent hole in the center of the cap and the NOS one doesn't  :o
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #3 on: June 25, 2012, 04:33:55 PM »
Oh well, solved.... sort of.  I tried to drill out that spot on the new cap hoping it was just capped and still had a passage underneath.  Nope, I snapped two drill bits attempting to drill it out at two different spots.  So the seal will come off and go on the old cap  :(
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #4 on: June 25, 2012, 05:00:27 PM »
Well, I took a short break and got the bit out of it.  I used what was left of the bit and got through the cap.  Blew it off with compressed air and it vents fine now.  Since I already put the other cap on, I'll just sit this on the shelf until I need it.  That was an odd episode...    ???
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Magilla
  • My bike: 1976 CB750F
Re: Gas tank builds pressure (solved: had to drill gas gap)
« Reply #5 on: June 26, 2012, 05:26:06 AM »
Are you building pressure or building vacuum?  There should be nothing more than atmospheric pressure in your tank at any time.  If your building vacuum it is the result of your cap not venting.  I've had that issue with a few bikes in the past.  For some reason it happened in high altitudes for my FXR.
My recommendation is to replace your cap.  Drilling it can allow trapped filings to get into your fuel system.  Bad things happen when pieces of metal make it into your fueling system.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
