What bike???........or did I miss that??
When you install rocker shaft/rocker assemblies, the generally accepted convention (IIRC), is to ensure the rocker/tappet adjuster screws are backed right out....this is to ensure the valve(s) are not pre-loaded as/when you screw the rocker shaft/rocker box down onto the head.
Once you've installed the rocker assembly (for running), you need to engage the cam lobes and their respective valves, in a correctly phased manner....until you do that, you cannot simply look for the valve to fall and rise..........(unless you install the rocker shafts with the adjuster screws turned in...in which case there is some added danger that they are not as you removed them.......and, even if they are, a rocker box which holds rocker shafts will not be torqued down correctly, if the rockers are pre-loading the valve(s) as you bolt/torque it (the rocker assembly) down onto the head.
