Author Topic: CB350G engine rebuild - O-Ring questions  (Read 916 times)
Offline petersan
« on: July 06, 2012, 08:42:56 AM »
Tried searching the forum and reading engine rebuild threads to answer this question.
I'm putting an engine back together after replacing a shredded cam tensioner and cam chain. When I pulled the engine apart, I noticed that a crushed O-Ring dropped out (I think when I removed the head from cyl), but I'm not sure where this would have gone. The parts fiche that I've looked at doesn't seem to show any O-Rings in the engine aside from the ones at the bottom of the cyl. I have a gasket kit, but it doesn't seem to have any small O-Rings.
Can anyone confirm that there should OR should not be O-Rings as I assemble the engine - and if needed, provide size or diagram showing placement?
Thanks!
Offline grcamna2
Re: CB350G engine rebuild - O-Ring questions
« Reply #1 on: July 11, 2012, 11:57:25 AM »
Hi Petersan,
         I think it's possible that the o-ring may have come from one of the rocker arm/ valve adjustment shafts.There are 4 of those shafts;when the cam tower's are installed along w/ the camshaft, there needs to be an o-ring underneath the washer and locknut for each shaft.
75' CB400F/'bunch o' parts'
