Just checked TDC, put on head , set tappet clearance etc rotated 3 turns , pulled head ..........all good
clearances ended up with including head gasket 1.3mm thick ( bout .050 thou)
valve to piston inlet.... 1.8mm ( .072 thou)
exhaust..2mm ( .080 thou)
Gap from spark plug tip to piston flat (not drilled relief) 1.7mm ( .068 thou)
piston edge squish band 1.6mm, next flat stage 1.6mm,
Bottom line it all misses
