Dirty points not allowing contact, try a point file or emery along with some electronic cleaner and recheck...Larry
Never use emery file or sand paper unless they are burned. You can just slide a piece of copy paper through the points and it will help re polish the surface.
The points surface is a mirror polished surface when new.
If the surface of the points is all pitted I would just buy some new points and condensers. IF you can get the gap correct and the dwell right at the same time then you are ok.
If you just clamped on a timing light to a spark plug wire instead of grounding the plug you can see if there is a spark even when it is hard to see on the plug.
With the timing light it is very easy to see. That way you do not need to hold the ground of the plug on the engine and risk getting shocked.
