Author Topic: Tarozzi rearset question -  (Read 676 times)
Offline Cevan
« on: September 18, 2011, 06:06:07 PM »
I'm in the process of fitting the Tarozzi rearsets on my '76 750F1.  These are the ones that can be bolted right on.  I noticed that the brake pedal spindle that came with the set is slightly different than the stock one.  The arm that comes off the spindle that the master cylinder splunger connects to is shorter by about a 1/4".  This causes the splunger to not be in line with the master cylinder.  Anyone else have this problem?  Will this be an issue?   I'm just mocking up my bike right now so I can't actually test it out.
« Last Edit: September 18, 2011, 06:09:38 PM by Cevan »
Offline MattFreeman
  • What Have I Done?
Re: Tarozzi rearset question -
« Reply #1 on: July 09, 2012, 08:30:43 PM »
Hey, if you're still around, did you get your rear sets on and are you happy with them?
I have the same bike and am considering the same set of uh.. sets. :D
