Author Topic: cb750k Carb swap Question (77-78)  (Read 948 times)
Offline tommy_k
« on: July 09, 2012, 07:17:00 PM »
I am a newby so take this with a grain of salt :) If it has already been posted I apologize, I did not find it anywhere yet.
I currently have a 78 cb750k and one of the brass nipples that runs into the base of the carb #2 body broke off. I tried to get it out from the other side by hammering an exact diameter rod through but then I realized I punched through a specifically cut hole. need less to say I think I messed it up. part is PD42BA
So my question
Are my carbs toast?
Fill any 78 cb750F or cb750F K carb setup work?
Can I use the previous year 77 cb750k or f carbs?
Thanks again!
Offline harisuluv
Re: cb750k Carb swap Question (77-78)
« Reply #1 on: July 09, 2012, 07:26:14 PM »
F PD carbs have a different air vent mechanism-no tubes.  What you need to do is just replace the body.  Go the "items wanted" section and list your PDXXXX numbers and year/make and someone will probably help you.  I probably have one if you choose to go that way.
Offline tommy_k
« Reply #2 on: July 09, 2012, 07:39:43 PM »
Thanks for the quick reply!
Offline lucky
« Reply #3 on: July 09, 2012, 07:46:43 PM »
I wish you could show us what you are talking about. ???
Offline lucky
« Reply #4 on: July 09, 2012, 07:48:02 PM »
The carbs are NOT toast!!!
Offline tommy_k
« Reply #5 on: July 09, 2012, 08:05:10 PM »
I will as soon as I get a pic.
Offline tommy_k
« Reply #6 on: July 10, 2012, 05:01:55 PM »
Side of carb # 2 where base of brass nipple is stuck.
Brass nipple that broke off
