Author Topic: 76 cb750k caliper  (Read 907 times)
Offline unkle fester
76 cb750k caliper
« on: June 20, 2006, 04:01:14 PM »
what year front caliper are interchangeable with a 76 cb750k????  I am assuming just 69-76 but I want to be sure
bowhunter
Re: 76 cb750k caliper
« Reply #1 on: June 20, 2006, 04:06:48 PM »
I believe that except for some minor external appearance changes, all of the 69-78 year calipers are interchangable on the K's.
Don't know about the F's or SS's.
Bowhunter
« Reply #2 on: June 20, 2006, 06:19:38 PM »
thanks...I wasn't sure....there are different part numbers for the 76 and 77..........
Offline Clyde
« Reply #3 on: June 21, 2006, 01:27:03 AM »
The calipers are the same from the K0 to the K6
The K0 is silver but theĀ  caliper is the same as the K1-K6(black).
Note however the arm ,that the caliper bolts on to, changed from the K3 onwards and was the same up to K6. The K0-K2 have the same arm.
The F/F1/K7/K8 used a different type of arm as well as caliper.
If you used both arm and caliper from a F/F1 series it would work on a K6
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
