Looks to me you are VERY close to negative trail. If you are and ride it that way ,it could be a KILLER.. Be very carefull because NEG trail cause a bad wobble.
Xnavylfr(CHUCK)
How could you tell it has too much negative trail from a poor quality photo???
Ridiculous.
Any negative trail is bad,Any trail under about 3 3/4 - 3 1/2inches is not what you would want, 4 inches is a good number for a reasonably stable ride, its also relative to rake... that blue bike will not have negative trail, just a little less than stock, which i don't recommend as it makes the steering more prone to "do what it likes" like falling into corners and tank slappers. If you must lower the front make sure you
Here is what you need to do.
First you should read about rake and trail. Many websites. FREE.
One of the most important pieces of information you did not even give us. When you changed forks was it just the fork tubes or did it include the triple trees?
You need to know if you changed the amount of offset in the triple trees.
You can do a simple measurement to find out how much trail you have. Then you can compare it to the amount that it had stock. Just do not go below that number.
You won't go wrong with 4.5 inches of trail.
Next have someone help you and push the front end of your bike down and make sure the front wheel does not contact the headers. Or you can use tie down trailer straps to pull the front end down a little at a time.
You can safely move the fork tubes up in the stock triple clamps ONE INCH.
lower the rear about the same amount as "really" has done....
Lucky, the K model 750's, depending on which K have a fraction under 4 inches of trail to just over 4 inches for the F {i think later K models have more trail but not 4.5 inches..., 4.5 inches is getting into slow steering territory. Looks like he used the stock triple clamps so offset won't change, 60mm is stock for a K model although 50mm will work as well a little better by adding a small amount of trail. Less offset means more trail and visa versa. Its all a compromise, a lot of research goes into getting rake and trail good on any bike, swingarm pivot position , swingarm length and tire and wheel sizes all factor into the equation as well.... Have a headache yet....
