Author Topic: pod filters... what do i do with the breather tube?  (Read 5499 times)
Offline cben750f0
« on: May 11, 2005, 09:17:15 AM »
ok all, here goes, picked up a set of old school pods the other day, you know the type, they go over two carbs, and are domed, with foam inside, UNI filter still make the dom elements, so have cut them down to suit my filter holders, now my question is, what do i do with the crank case breather, it used to run to the top of the airbox, and now that i dont have an air box, what to do... the 77 has a seperator,element type thing under the batterie, can i just put a little breather filter on the end of the tube, and be done with it?... any help would be appreciated... peace
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: pod filters... what do i do with the breather tube?
« Reply #1 on: May 11, 2005, 09:19:51 AM »
Just run it with all the other tubes down the back of the engine and let it vent to the air.
Who needs all this 1970's environmental plumbing anyway??
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #2 on: May 11, 2005, 09:39:08 AM »
I use a K&N vent filte at the end of the tube and zip tie it to the bolt hole that used to hold the OEM breather cannister. Uni makes them too.
Bobby
« Reply #3 on: May 11, 2005, 11:36:35 AM »
I'm using Velocity Stacks and I bought a pair of these filters from eBay for low money.  They're not K&N's but they are washable.  3/8" inlet.  Worked out fine for me.
-Bobby
Offline cben750f0
« Reply #4 on: May 11, 2005, 05:24:41 PM »
very coolness everyone, when i get it all sorted will post a pick... cheers...peace
phylo101
« Reply #5 on: May 19, 2005, 02:21:52 PM »
Yep, most cool dudes fit those lil filters meant for the oil filter to airbox line on Harleys when you swap out the dinosaur's airbox for an after market one. Have also seen them used to plug the top of the v=crankcase vent thats on top of the gearbox on Kwack Zed's. But most folks used to just let Hondas vent to the air.
phylo
« Reply #6 on: May 19, 2005, 06:22:04 PM »
phylo
Phylo.....our Irish friend. I always think of pastery dough when I see that name. Welcome back.  ;D
Offline cben750f0
« Reply #7 on: May 24, 2005, 05:36:08 AM »
here's my pod, now all i ahve to do is find a place to mount it!!!!.any ideas...peace
« Last Edit: September 01, 2007, 03:39:23 PM by Glenn Stauffer »
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #8 on: May 24, 2005, 05:40:42 AM »
That's pretty spanky - where'd you get it?
Roule comme dans les années 70...   Roll as in the Seventies...
Offline cben750f0
« Reply #9 on: May 24, 2005, 06:36:28 AM »
did a search on ebay for a breather filter... and this is one of the designs that come up, my only prob now is i cant fint a place to fit it, it looed smaller in the pick.... ::)..peace
Steelo
« Reply #10 on: May 24, 2005, 07:21:00 AM »
Cben a Snr Member Mcpuffett has one of those breathers mounted on his bike on the right near the end of the kick start lever looks pretty cool.
Offline cben750f0
« Reply #11 on: May 24, 2005, 07:22:50 AM »
yeah saw that, but my only worry is if its riden in the rain, getting water in the breather... plus i still wasnt sure were he had it hanging off... so thought someone might know, thanks for the point in the right direction...peace
Offline mcpuffett
« Reply #12 on: May 24, 2005, 09:12:02 AM »
hello ben ,see you got one of those nice little breather filters 8) on the left hand side of your bike there is an engine mount i used the top bolt to mount mine on had no issues riding in the rain or washing bike for that matter as it is lower than top of engine  ;) i do get a bit of a mist on my side panel, condensation with a bit of oil mixed in  :) other than that it is cool 8) mick.
« Last Edit: May 29, 2005, 07:29:32 AM by Glenn Stauffer »
Offline dusterdude
« Reply #13 on: May 24, 2005, 10:46:22 AM »
mick,do you know if that rear mc setup will bolt on a 750 k frame?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline mcpuffett
« Reply #14 on: May 24, 2005, 02:16:04 PM »
hi again apologies to ben i should have said right hand side of your bike :-[, hey duster dude i don't know about master cylinder set up maybe some other members may know  :-\  mick.
Offline cben750f0
« Reply #15 on: May 24, 2005, 06:14:52 PM »
yeah that was actually the first place i bolted it, then had a reconsider....thanks for the input..peace
