Author Topic: CB750 F2 - race engine  (Read 1852 times)
Offline dakota
« on: July 16, 2012, 05:01:33 AM »
Hi,
we have a CB750 F2 1978 and we would like to build a racer.
We aren't going for the bigborekit and decided to stay on 734cc.
These are the modifications that we already have planned tot do.
What can we still do to get a "fast" bike?
- seals,o-rings, ...
- electronic ignition
- camshaft 41a or ...
- racing cam tensioner + chain + adj. cam sprocket
- primaire chains + tensioner
- titanium retainers
- bronze valve guides
- heavy duty valve springs
- heavy duty cilinder studs
- valves?
- rods?
- porting the head
- lightening the crank
perhaps (not for the first races)
- keihin cr
- nova close ratio gearbox
thanks
Offline voxonda
Re: CB750 F2 - race engine
« Reply #1 on: July 16, 2012, 05:22:07 AM »
Hey Dakota,
Most of the thing you mentioned aren't going to make the bike any faster. But are a good choice to make it (even) more reliable.
Building a race bike isn't just about the amount of power, you will have to be able to 'put' it on the street/track as well. Most power is made in the cylinder head. If you want torque you should go big bore. But from what I have experienced with my bike during demoraces including the 3hour of Oss is that no matter what power you have, the rider is the most important factor. We've raced a 'good' F2, just new rings, carefully build engine, 41a Webcam, good ignition, race clutch and special prepped FD carb's and a good pipe!
There where some younger, in theory, faster bikes that could not stay with us, neither in corners nor in straight line speed. Although there is still a lot to gain, the engine seem to be very reliable. Havent touched it after the 3 hour beating.
Cheers, Rob
« Last Edit: July 16, 2012, 05:32:19 AM by voxonda »
Offline bear
  • Leeton in Australia
« Reply #2 on: July 16, 2012, 05:48:27 AM »
Cheers, Rob
I'm with Rob.
If you want a fast road racer get it to steer, stop and dig it's toe's in.
Brian
Offline voxonda
« Reply #3 on: July 16, 2012, 12:07:04 PM »
Hey Dakota,
Do not let us discourage you. No intention for that, but seen a lot over the years. Highly tuned engines blowing and or crashing out first time out. It is about the total package.
« Reply #4 on: July 16, 2012, 01:18:05 PM »
+1 on what you've just heard. And possibly up the compression, bigger cam than the 41A with some serious head work.
Offline voxonda
« Reply #5 on: July 16, 2012, 01:42:23 PM »
Do not forget to addept the pistons if using another than the 41a! Need to adjust the pockets.
Offline dakota
« Reply #6 on: July 17, 2012, 02:14:47 AM »
Hi,
Thank you for the replies.
After these replies we aren't at all discouraged, but now we know what we can expect and what we have to do to get a reliable engine.
- ignition
- 41a cam
- segments
- oil cooler
- seals, o-rings, chains,...
We're going to start with these modifications and then focus on the frame and aerodynamics.
