Author Topic: How much oil pressure at idle? 750 k5  (Read 1509 times)
Offline 1974cb550k
« on: July 14, 2012, 12:11:41 PM »
I got the bike going but have only 18-20 psi of oil at idle. It ramps up fine with the throttle but i was curious to know what you guys were getting Thanx
Re: How much oil pressure at idle? 750 k5
« Reply #1 on: July 14, 2012, 12:22:35 PM »
That is more than sufficient at idle IIRC.
Unless my gauge is goofy, on a newly rebuilt engine I'm getting 60+psi at all rpms.  I'll be swapping gauges this weekend to test as i think this is high.
But yours is OK from what a know about it. Should get to 60+ by 3000 rpm.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: July 14, 2012, 02:04:17 PM »
When you say "idle" what RPM's? You can figure approx. 10 lbs/1,000 RPM when the engine is warmed to operating temp.
Offline 1974cb550k
« Reply #3 on: July 15, 2012, 06:47:19 AM »
1200 rpm @idle
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: July 15, 2012, 08:00:15 AM »
Sounds like you are fine. Keep in mind variables in gauge accuracy,  both tachs and pressure, ten lbs per 1,000 is pretty standard. It may vary 'slightly' depending upon ambient temps. When warmed,  but riding in March, it may run a few lbs higher per 1,000 rpm and at 95F in July,  a bit lower.
« Last Edit: July 15, 2012, 08:01:59 AM by Bob Wessner »
« Reply #5 on: July 15, 2012, 11:42:24 AM »
Thats what mine reads after a long ride on hot day. Cooler days are 30 or so.
Yours is fine - what oil btw?
bollingball
« Reply #6 on: July 15, 2012, 11:46:47 AM »
Is this a trick question ;D
« Reply #7 on: July 15, 2012, 11:52:41 AM »
Of course  ;D
The weight makes difference in pressure - mine is 20W50
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: July 15, 2012, 01:07:57 PM »
Of course  ;D
Good point. I use 10w40. I refuse to divulge the brand.  ;)
bollingball
« Reply #9 on: July 15, 2012, 01:50:43 PM »
Good point indeed, Also to the OP Have you read this?
http://forums.sohc4.net/index.php?topic=78643.0
Ken
