Author Topic: 82 CB650SC, VB 54 carburetors questions  (Read 1721 times)
Offline Nezer
« on: July 15, 2012, 09:12:45 AM »
Hello
I have a small problem with the carburetor on my bike. I installed a new float valves, and all carburetors have a different fuel level marked on the image. The question is which one is correct?
The second question is, what should be pilot screw settings in this carb type?
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: 82 CB650SC, VB 54 carburetors questions
« Reply #1 on: July 15, 2012, 10:41:24 AM »
Do you have a shop manual?  The procedure for checking float levels and setting pilot screws will be in there.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Nezer
« Reply #2 on: July 15, 2012, 11:33:52 AM »
I have, but unfortunately to the PD carb version, and i can't find my CV version.
I know that the floats level should be 15.5 +-1mm,  and float valve should be closed in this position. I wanna make sure only.  Maybe someone can check what fuel level he have, and which level on photo is correct.
I have pilot screw setting to VB 44, VB 45,  but i don't have nothing about my version VB54.
Offline kslrr
« Reply #3 on: July 15, 2012, 12:11:55 PM »
Ok, so you know that the float level should be 15.5 +-1mm, and that would be the measurement from the "deck" of the carb body to the "top" of the float with the float valve just closing.  This is done with the carb rack off the engine with the bowls removed.  The procedure should be the same for different models of carbs.  There should be photos in your manual showing this.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
