Author Topic: CB550 f2 '77 carb set up  (Read 3436 times)
Offline Sherlock
    • A Cafe Racer is Born
« on: July 15, 2012, 12:42:24 PM »
Can anyone advise what set up I would need for the CB550 f2 carbs fitted with pod air filters. The ones I'm considering are these...
http://bit.ly/M0FZBe
Here's the carbs...
Thanks in advance.
Sent from my iPhone 4 using Tapatalk!
Offline Sherlock
« Reply #1 on: July 15, 2012, 11:39:17 PM »
The exhaust would be a 4-1 mac.
Offline luap
  • LAWL
Re: CB550 f2 '77 carb set up
« Reply #2 on: July 16, 2012, 09:01:47 AM »
35mm is what you want not 43mm is to big
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline Sherlock
« Reply #3 on: July 16, 2012, 11:39:45 AM »
Ah, doh, cheers buddy. :-)
Ay idea what size jet(s) I need?
Offline Sherlock
« Reply #4 on: July 25, 2012, 06:03:09 AM »
Anyone know what jest sizes needed for these carb pods? http://bit.ly/NJuXSF
How will the bike run if using standard (service kit jets etc)? Will it be a bag of sh** and run too rich?
Offline sinister902
    • Anger Street Kustoms
« Reply #5 on: July 25, 2012, 09:01:43 AM »
stock jets will run it lean on pods. get #40 pilots and 105mains. leave needle clip in stock position, put mixture screw 3/4 turn out.
Offline Sherlock
« Reply #6 on: July 25, 2012, 09:22:28 AM »
Thanks mate. Couple of q's
Where can I get the jets from?
What is the stock pos of the needle clip.
Thank you :-)
Offline sinister902
« Reply #7 on: July 25, 2012, 09:33:19 AM »
stock clip position is 4th from top (there are 5 notches)
I've gotten my jets all from JetsRus.com but you are in the UK so I'm not sure that's a viable source for you. based on the picture you provided those are 022a carbs, which use the "push-in" style keihin main jets and threaded pilot jets. JetsRus would be a good place to look at the picture to see what they look like if you need to know, and maybe then search for a more local source.
bollingball
« Reply #8 on: July 25, 2012, 10:03:43 AM »
Is that correct or are the pilots push-in?? Just asking ;)
Offline Sherlock
« Reply #9 on: July 25, 2012, 11:59:27 AM »
My carbs are 069A's
They have push in pilot jets.
Offline harisuluv
« Reply #10 on: July 25, 2012, 12:18:19 PM »
Yes, those carbs have push in jets.  They are held in place by the leaf spring and is fitted with an o-ring.
Offline Fritz
« Reply #11 on: July 25, 2012, 12:25:18 PM »
My carbs are 069A's
Strange - my 550F's got 069A carbs too. The slow jets are threaded... The main jets are pressed in and held by o-rings and the leaf spring.
Anyway, before jumping into the joy of finding the correct jets and needle positions for your custom intake, you should make sure that all the jets, orifices and passages in the carb bodies are free. Run thin steel guitar strings or single strands of control cables through the passages. Pay special attention to the idle circuit that is running from the carb's intake to the idle adjustment screw, touches the passage where the pilot jet sits and ends with a tiny hole just in front of the slide. You'll also need to take out the needle jets/"emulsifier tubes" and clean all their tiny orifices. Use copper strands for the jets, since steel will damage them.
It's a time consuming process and I have a fealing that a lot of the problems that people with pods on their carbs have, have their reason in carbs that have not been cleaned thoroughly.
1976 CB550F
Offline Sherlock
« Reply #12 on: July 25, 2012, 01:44:08 PM »
My carbs are 069A's
My mistake. Your right :-)
I'm actually stripping the carbs to bits and thoroughly cleaning. Thanks for the tips :-)
