Author Topic: has anyone tried repainting their switches?  (Read 8767 times)
Offline R. Hykawy
  • 77 CB400F Winnipeg,Canada
« on: March 31, 2005, 06:39:33 PM »
Hi, I was just wondering if anyone has tried to repaint their switches( turn signal and run /start switches). If so how did they turn out and what shade of black did you use?  ???
Richard
77 cb400F
Richard Hykawy
Re: has anyone tried repainting their switches?
« Reply #1 on: March 31, 2005, 08:07:42 PM »
G'Day Richard, I painted mine with VHT Satin Black after first "etch priming" them to ensure that the paint would stick. I then cooked them in my kitchen oven (while the wie was out) to cure the paint. I went to my hardware store and bought some small "sample" cans of water based acrylic interior paint and a couple of model brushes and some cotton wool buds, and a saucer of water.
I then, very patiently, dribbled paint from the model brush into the impressed lettering on the switches, in the correct shade, using a cotton wool bud moistened in water (but not dripping) to quickly wipe off any excess. Once dry, it'll last as long as the original paint, and the advantage of a water based paint is that you don't need to use a chemical like thinners or turpentine to remove any excess, which might also damage the black paint.  Cheers, Terry. 8)
Offline R. Hykawy
« Reply #2 on: March 31, 2005, 09:00:16 PM »
Terry, thanks for the reply. How long did you "cook" them for and at what temp? Was there much odor? You know the wife thing.
Richard
Richard Hykawy
« Reply #3 on: April 01, 2005, 02:50:39 AM »
G'Day Richard, the "baking" instructions should be on the can, but from memory it was around 30 minutes at 200 deg F? Something like that anyway. Yeah, it stank out the kitchen a little, so I purposely burned a cheese sandwich to confuse her sense of smell, ha ha! One day I'll buy an old oven and set it up in my garage, geez, I might even buy one of those pwder-coating guns that they sell at The Eastwood Company, wouldn't that be neat? Cheers, Terry. 8)
Offline Triffecpa
« Reply #4 on: April 01, 2005, 05:56:55 AM »
" Yeah, it stank out the kitchen a little, so I purposely burned a cheese sandwich to confuse her sense of smell, ha ha! "
And my wife thinks that I'm devious.  I stand humbled before the King...
cb750_chris
« Reply #5 on: April 01, 2005, 06:36:54 AM »
Burn A cheese sandwich ;D ;D ;D.  I'll have to remember that one next time I'm cleaning parts in the kitchen sink.  I can keep the mess to a minimum and clean it entirely up.  But the smell of WD and Castrol degreeser always gives me away.
« Reply #6 on: April 01, 2005, 06:48:23 AM »
I've heated a few cylinder heads in the oven and honestly it's smelt better than some of my wife's cooking. PJ1 Black Satin Case Paint is an excellent product too. I place any spray paint can in hot water for 5 minutes prior to using it- the paint levels nice.
« Reply #7 on: April 01, 2005, 02:23:01 PM »
Try the dishwasher mate, it makes an excellent parts washer! Cheers, Terry. 8)
CB400FAN
« Reply #8 on: April 01, 2005, 03:25:53 PM »
Hi. I painted the switches on my 1978 CB400F2 with satin black, and picked out the lettering in humbrol red ennamel with a cocktail stick. I too baked mine in the oven while my wife was there           (she's very understanding) at 70 degrees centigrade for 30 minutes. They turned out really well and I would strongly reccomend the cocktail stick as a paint brush.
munzerelli1959
« Reply #9 on: April 02, 2005, 03:00:27 AM »
Hi. I have sand blasted my housings, etched them, u/coat then sprayed a few coats of metalic charcoal on them. Just baked them in the good ol Aussie sun. Came up well. For the white lettering i simply used the good old "whiteout" that secretaries use when they stuff up their typing!
Hope it helps.
Chris.
« Reply #10 on: April 02, 2005, 04:59:03 PM »
Hope it helps.
Chris.
G'Day Chris, I do pretty much the same re: preparation, I bead-blast the housings (kinder on soft alloy than sand-blasting) in my little bench top blaster, then use "High-Chem" brand etch primer, (no regular primer is required with this stuff, you can paint straight over it)  then I just lay on a couple of light coats of VHT, the idea being not to fill the cast letter depressions with paint, leaving plenty of room for the lettering paint. can you still buy "white out"? I would have thought nowadays a secretary would just hit the "delete" key? Ha ha, Cheers, Terry. 8)
« Reply #11 on: April 02, 2005, 05:54:33 PM »
Hey Terry, don't you mean "talcum powder blast". Buck up and change that media! ;D
« Reply #12 on: April 02, 2005, 07:05:55 PM »
You're right Mike, it's pretty sad at the moment, I tried blasting an F2 M/C that I'm rebuilding, and it wouldn't budge it? Bloody hell................. :o Cheers, Terry.
Spear
« Reply #13 on: April 05, 2005, 05:05:39 PM »
Terry. I remember years ago being able to buy a craft paint product called "Hobbytex" that you could squeeze onto fabric to 'paint' with. It was an acrylic product and had some great colours. I'm sure it's still available. That is fantastic for detailing stamped lettering etc. I remember in 1978 I detailed my .38 Smith and Wesson with it. I had the revolver re-blued, then did the Smith and Wesson on the barrel with blue, the S&W logo with gold and the NSWP logo in the original blue, green and gold colour scheme. Looked bloody fantastic and stayed there for years until I had to hand it in and have it replaced by a .40cal Glock. The Hobbytex is squeezed onto your stamped lettering, then when you wipe over it to wipe off the excess it pushes into the stamping and stays there. Sticks like sh!t to a blanket. I'm pretty sure this was an American product, so it should be available state-side. I'll check my local Spotlight store tomorrow for it and let y'all know.
x2qwk4ux
« Reply #14 on: April 06, 2005, 02:17:36 AM »
I just sended & polished mine up.  It took some work, but they're really shiny now.  Then I did the upper triples.  Then the cases.  My fingers are still pretty sore, but what the hell.  Bike looks great!
paulscb750
« Reply #15 on: April 23, 2005, 08:43:33 PM »
Well this is a little off the switche topic but what would u sugest for painting the frame, lightsand and paint or sand blast and prime and paint??????????????????????? it would be a great help if u could give me some hints thanx
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #16 on: April 23, 2005, 10:06:31 PM »
paulscb750
LET ME KNOW WHAT YOU DECIDE TO DO I WANT TO PAINT MY FRAME.
terry
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
Offline kghost
« Reply #17 on: April 23, 2005, 10:09:35 PM »
I powdercoated my switches.
Stranger in a strange land
cb750_chris
« Reply #18 on: April 24, 2005, 05:46:47 AM »
Will powder coat hold up against brake fluid?  I'm looking for a shop to re-anodize mine but the last shop I found said they couldn't do it with the type of metal they are made from.  He said that they were not a good grade of aluminum but rather some sort of pot metal.  He said the factory was abble to do it because they were freshly cast.  Trying to re-anodize them would only lead to pitting.  I would really like to have them anodized so that I don't have to worry about the brake fluid issue.  + I would be pissed if the powder coat got inside the master cylinder.
Offline kghost
« Reply #19 on: April 24, 2005, 09:31:10 AM »
Yes the powdercoat will hold up to brake fluid. I used DOT-5 silicon brake fluid though. The Master cyl. I polished but there is no reason why you couldn't powdercoat it.
Recommend you put the cap on and use a plug on the port when you spray it (before baking)
Spear
« Reply #20 on: April 25, 2005, 06:50:16 AM »
There's only one way to paint a frame - black 2-pack enamel. I recall reading a post on our old site about someone powdercoating a frame, and discovering that it didn't like petrol. Anyone remember that?
Offline Paul
« Reply #21 on: April 25, 2005, 07:04:19 AM »
I anodised my switches...just to see. the anodisers said they would turn out crap because of the low grade material....so I did...and they did (freebie anyway), so I painted over them 'cos it was too much bother to powder coat them at that late stage. I did however powdercoat my frame and its 100%. just make sure to sandblast it first and run to the coaters before it gets a breath of fresh air. if it's not prepared properly the coating will lift off in sheets. Petrol ? I've had no issues, but then again I havn't spilt much either....well, only onto rags when draining the carbs.
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
Offline kghost
« Reply #22 on: April 25, 2005, 09:37:59 AM »
You'd have to take the powdercoating off mine with a hammer or paint stripper. It resists everything else so far.
cb750_chris
« Reply #23 on: April 25, 2005, 10:59:46 AM »
My powder coater said to only blast it off.  If I had tried to strip it with paint stripper it would have made it harder.  Trying to blast it after that would have been more expensive.
Offline kghost
« Reply #24 on: April 25, 2005, 02:32:06 PM »
I generally prep all the small stuff before taking it to the coater. Keeps the cost down.
The only powdercoating I have had to remove was taken off with Aircraft stripper, which seems to be a little (ok alot) more potent the the Wal-mart stuff. Then I bead blast it.
« Reply #25 on: April 25, 2005, 04:21:30 PM »
I've never heard of powdercoat coming off with petrol (Gasoline) or brake fluid. I got a frame coated last year (on my F2) and the coter asked me if it'd been previously powder-coated, I asked why, and he said they charge extra because they have to burn it off, and then sandblast the remains off.
I wasn't too keen at this prospect, so was happy that mine was just the rusty old factory paint job, plus a bit of rattle-can art from a PO. Two pack (2K) is great paint, but not a patch on powdercoating, and a lot more expensive when you add all the components required to do a good job. Cheers, Terry. 8)
