Author Topic: Ignition problem? Solenoid problem?  (Read 2412 times)
Offline sugarfinger
« on: July 16, 2012, 07:10:37 PM »
Can anyone tell me what would cause the starter to go when I turn the key to on1?
'75 750.  I have a brand new harness from cb750 supply and everything stock except for turn signals and tail light.
Thanks
1975 CB750
Offline Rob69
Re: Ignition problem? Solenoid problem?
« Reply #1 on: July 16, 2012, 07:24:58 PM »
Thanks
Sounds like a short circuit. Question: Is the right hand handlebar switch harness routed inside the handlebar? If so, did you remove and install the switch recently, or have the switch apart? To stop it from doing what it's doing, remove the headlight and disconnect the yellow wire with the red tracer until you can track down the problem.
Offline sugarfinger
« Reply #2 on: July 16, 2012, 07:37:33 PM »
[/quote]Sounds like a short circuit. Question: Is the right hand handlebar switch harness routed inside the handlebar? If so, did you remove and install the switch recently, or have the switch apart? To stop it from doing what it's doing, remove the headlight and disconnect the yellow wire with the red tracer until you can track down the problem.
[/quote]
I forgot to mention I changed the bars.  I had to rewire the right hand controls and the wires no longer run through the bars.
1975 CB750
« Reply #3 on: July 16, 2012, 07:53:20 PM »
Stock wiring for the right-hand '75 switch: Black is power to the switch, and Black/Red (usually) comes back from the Start button as Headlight power when it is NOT pressed. When you press it, the power comes back on Yel/Red instead, which causes the headlight to go out while START is active.
« Last Edit: July 22, 2012, 10:01:58 PM by HondaMan »
Offline Rob69
« Reply #4 on: July 16, 2012, 08:04:17 PM »
Look for an exposed wire. I had the same problem with my CB350F restoration project. I found the yellow/red wire exposed and grounding out against a metal guide inside the switch at the starter button. It's also possible that the starter button is sticking. If you have an ohm meter and a shop manual, perform the checks outlined in the manual to ensure that the switch is opening and closing properly.
« Last Edit: July 16, 2012, 08:05:59 PM by Rob69 »
Offline sugarfinger
« Reply #5 on: July 17, 2012, 03:43:47 AM »
Starter button is functioning properly.  I'll start searching for a short circuit... I can't imagine where though because the harness is new.
The right hand controls have the headlight on/off switch.  The wires are br/wt, bk/wt, bl, bl, y/r, and grn/rd.
« Last Edit: July 17, 2012, 04:14:53 AM by sugarfinger »
1975 CB750
« Reply #6 on: July 22, 2012, 10:06:38 PM »
Did you buy an EGO harness (PartsNmore, et al?). The Yel/Red and Grn/Red wires that run the Starter solenoid might be screwy. I just had to rewire one of those today: made a male-male Yel/Red to connect to the solenoid from the harness, and tied the solenoid's Grn/Red to the spare Grn under the seat with a male spade on one end, female bullet on the other, 1" long jumper(s). This EMGO PartsNmore harness presumes a grounding START button at the handlebars, has a female Blk at the starter solenoid (as in K0-K2 bikes), yet it is listed as a K3-K6 harness. Seems to be a kitbash of 2/3 of both harness types?
Offline sugarfinger
« Reply #7 on: July 27, 2012, 08:50:27 AM »
Harness is aftermarket so probably.  I got the starter switch working by attaching the yel/red on my switch to the yel/red on the harness and attaching the grn/red from the switch to the lt grn/red on the new harness.
I have a few more gremlins to figure out now but I'm close.  I'm gonna do more searches here before I ask a dumb question.  Thanks to all for the help thus far... I would be lost without this forum!
1975 CB750
Offline Bristledisk
« Reply #8 on: September 21, 2022, 01:09:04 PM »
Thanks to this 10 year old post, my problem with my 350F whereby the starter motor kicked in as soon as the key ignition was turned on, but before the starter button was pressed, is solved. The yellow/red wire was grounding in the Right Hand switch. I repaired the frayed wire, and the starter motor now comes on only after started button is pressed.
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
« Reply #9 on: September 21, 2022, 06:28:00 PM »
Good sleuthing!
