Admittedly, this may be somewhere on the forum already, but I can't seem to find it! If someone could point me in the right direction, I'd be eternally grateful.
Is there a trick to getting the main jet out on the cb350f? I can't seem to pull it.
I've read you can push it from the top, but when I remove the tops of carbs, the tops of the slide mechanism look to have special washers on it that are bent up around the nuts as if to keep them from turning. I'm wary of removing these but I'd like to get the main jet out so as to be certain it is both clean and the correct size. The idle jet was the correct size, but you can never tell with these things.
I managed to clean the main jet with a guitar string, but am not sure this is enough. Any ideas?
If it helps, I can take a picture of the slide mechanism bolts when I get home. I've tried to explain as clearly as possible, but I know how these things are.
