Author Topic: DSS Electronic Ignition.  (Read 10648 times)
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« on: July 17, 2012, 04:59:40 AM »
I've not noticed this kit on their site before today, but is anyone running this ignition from DSS spares?
http://www.davidsilverspares.co.uk/CB550F1-SUPER-SPORT-1976/part_192268/
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: DSS Electronic Ignition.
« Reply #1 on: July 17, 2012, 08:17:20 AM »
Looks like corrosion just waiting to happen with all that exposed electronics. Does it really cost that much to encase it in something waterproof? That's one reason I went with the Dyna S.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline wrenchmuch
« Reply #2 on: July 17, 2012, 08:51:47 AM »
I believe this unit is made in Germany . I think member Nippon deals these in the US . I've seen a knock off as well . In addition to what Duanob said I'm not sure the environment under the points cover is a great place to put electronic components due to the heat present there . For this reason I like Hondaman's unit which locates the electronics someplace cooler . Boyer bransden also does this by putting the pickup coils only inside the cover . Many electronic ignitions to choose from these days .
CB750K1
CB750K4
Offline nippon
    • Classic Cycle City
« Reply #3 on: July 17, 2012, 09:13:40 AM »
CMS is making them by Lang Fang Kokusan in Japan as you can read on the plate.
nippon
« Last Edit: July 17, 2012, 09:22:34 AM by nippon »
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #4 on: July 17, 2012, 09:35:13 AM »
They could have a conformal coating on them which is basically clear.  All of the circuit cards I deal with are coated in it.
Offline pangloss
  • CB500 K2 1975 NZ model
« Reply #5 on: July 17, 2012, 09:51:10 AM »
Had one of these in my 500-4 for 5 years without any  problems.   tms.ve run the bike up and down the Stuart Hiway (Darwin~Alice ) a couple of times and buzz around Darwin all the time.. .I had a look at it last weekend and it looks fine no sign of heat distress
« Reply #6 on: July 17, 2012, 07:45:42 PM »
go for it owen,get rid of them stinking points.
Offline Frostyboy
  • Circa 1951
« Reply #7 on: July 17, 2012, 08:11:18 PM »
I might just give it a go Dave, no drama about setting the timing for two, it looks like pickups are 180ยบ apart.
Built in timing light for static setting too it seems.
We haven't met yet.
[CB550F1]
« Reply #8 on: July 17, 2012, 11:34:59 PM »
check it at full advance with a timing light though and adjust it if it falls short or goes over.
« Reply #9 on: July 17, 2012, 11:59:43 PM »
I beg your pardon, my points don't stink. They have a fine, mysterious scent. If you must buy this, make sure the cover has a good seal.
« Reply #10 on: July 18, 2012, 12:13:53 AM »
the condensors smell even worse.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #11 on: July 18, 2012, 12:26:16 AM »
Frosty, I'm real happy with the Hondaman ignition unit also. It sits out of the way, has gotten great reviews from forum members uniformly, and it'll save you some significant coin as well.
Offline Frostyboy
  • Circa 1951
« Reply #12 on: July 18, 2012, 04:25:47 AM »
I appreciate what you're saying there Coach & with no disrespect to Hondaman's system, I'm looking to get away from the geometry puzzle to get both sets of points set to the same gap & have the timing correct on both sets at the same time. I'm not certain if po changed the points plate at some stage, but grrrrrr.
I've read about shimming the base plate to correct this problem, but it shouldn't have to be that hard. I can remember a post here about a member having the same issue even with the Dyna kit when he couldn't get enough advance on 2 & 3.
We haven't met yet.
[CB550F1]
Offline trueblue
« Reply #13 on: July 18, 2012, 05:52:08 AM »
Just get a 650 Owen no points to worry about ;D
1979 CB650Z
Offline Spanner 1
« Reply #14 on: July 18, 2012, 07:20:38 AM »
Frosty.... 'prolly a bent points cam shaft causing 2-3 not to set per specs. Putting an electronic on there won't fix that  ;)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #15 on: July 18, 2012, 08:46:52 AM »
 :D I like your thinking.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #16 on: July 18, 2012, 11:58:02 PM »
i have a spare points plate that times ok you can borrow till your new unit arrives owen,i also have a spare boyer system that runs the factory coils if you want to borrow that?
« Reply #17 on: July 19, 2012, 01:02:38 AM »
Oh goody, another points VS electronic ignition thread slowly forming, where's TT?  ::)
Offline Frostyboy
  • Circa 1951
« Reply #18 on: July 19, 2012, 03:19:02 AM »
Oh goody, another points VS electronic ignition thread slowly forming,  ::)
No no no!!! That's not what I meant  :-[
<--- wonders if a mod might lock this thread now.
We haven't met yet.
[CB550F1]
Offline trueblue
« Reply #19 on: July 19, 2012, 03:29:32 AM »
Just in case, I got the popcorn ready.
1979 CB650Z
« Reply #20 on: July 19, 2012, 03:56:44 AM »
I just poured myself another Jack Daniels Honey Liquer, let the games begin! ;D
Offline chewbacca5000
  • I polish covers!
« Reply #21 on: July 19, 2012, 06:19:24 PM »
+1 on the shaft.  Had this happen a week ago and I could not get 2,3 to go to full advance.  Hondaman helped me out on this one.  Making sure that shaft is true is key.
As for the whole points vs electronic it does not make a whole lot of difference if your engine is in tune.  My 73 cb750 pulls like a freight train with points.  It also has a fresh top end and a serdi valve job.
« Reply #22 on: July 19, 2012, 06:50:55 PM »
Not bad stuff Terry. ;)  I wonder is what kind of Oil would get the most out of a bike using lthis unit.
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #23 on: July 19, 2012, 07:48:49 PM »
I like to use the cheapest oil I can get....usually from wal-mart.
I like berries.
Offline BLUE71TURBO
« Reply #24 on: July 19, 2012, 09:58:19 PM »
              MAGNETO'S ! There is no substitute !
