Author Topic: cb550 cam tensioner frozen  (Read 630 times)
Offline lefty2023
« on: July 17, 2012, 01:53:44 PM »
hello, 77 cb550k.  i can grab the threaded piece of the cam tensioner and turn it in circles.  how bad is this? the locknut on the cam tensioner is frozen to the threaded screw and im trying to break it free but even if i free up the bolt thats frozen on the tensioner screw do i still have to remove the cam tensioner from the motor because i can rotate the screw?
77 cb550k and 77 cb550f
Offline LesterPiglet
  • 1977 CB550F2
Re: cb550 cam tensioner frozen
« Reply #1 on: July 17, 2012, 01:57:29 PM »
I'm afraid so. On the other end of that screw are little teeth that mesh with teeth on the tensioner. If you can rotate it 360 degrees then the teeth aren't meshing.
Offline lefty2023
« Reply #2 on: July 17, 2012, 08:21:28 PM »
alright, thank you!
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #3 on: July 18, 2012, 04:08:36 AM »
You might be hard pressed to find a replacement. If you can't find one locally, DSS are still showing one in stock. Unfortunately, at $194.11 + shipping, it's not a cheap thing.
http://www.davidsilverspares.co.uk/CB550F1-SUPER-SPORT-1976/part_176173/
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
