Author Topic: CB750 12v accessory wire?  (Read 1571 times)
78CB750F1
« on: June 21, 2006, 04:28:18 PM »
I need a 12v wire with constant power at the front to hook up a GPS - any recommendations on the best way to wire it?
howardstapley
Re: CB750 12v accessory wire?
« Reply #1 on: June 21, 2006, 04:30:40 PM »
Directly to battery with 15v quick-blow fuse, done in 2 minutes.
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #2 on: June 21, 2006, 05:29:35 PM »
You have 12v constant ozzing all inside your headlight shell.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
« Reply #3 on: June 21, 2006, 07:37:44 PM »
I believe that the imfamous "green wire" to nowhere on the 750 has 12V
Offline Lumbee
    • My pics...
« Reply #4 on: June 21, 2006, 07:41:15 PM »
...I though the green wire was always ground?  ???
"I'm not a welder, but I play one on HondaChopper.com"
« Reply #5 on: June 21, 2006, 09:45:52 PM »
What bike wire harness do you have?
Green ones are standard for Honda Ground, Black ones are ignition switched, red ones are live to battery.  The starter solenoid is a good place to tap off a battery, always hot connection.
