Author Topic: Keyless Ignition  (Read 3751 times)
Offline MattFreeman
  • What Have I Done?
Keyless Ignition
« on: July 17, 2012, 02:20:51 PM »
Is there anybody here that has made or used a keyless ignition on their dinosaur? Kinda like Nissan cars? Fob in your pocket and push a button?
I found one online but it was quite $$$, 350ish? And included a "security system".
I wondered if maybe Hondaman wanted to make one to go with his ignition.
Offline Dyrden
Re: Keyless Ignition
« Reply #1 on: July 17, 2012, 03:09:48 PM »
I've done it before and just happened to wire one up last night on my cb750 project. Costs like 50 bucks total.
There's a thread on customfighters.com with the info you'll need under lighting and electrical.
Offline matt mattison
« Reply #2 on: July 17, 2012, 03:47:04 PM »
I did it using The Motogadget M - lock. You need to pass the fob over the sensor, which can be hidden.
1975 CB550F
2011 MV Agusta Brutale 1090RR
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« Reply #3 on: July 17, 2012, 04:18:39 PM »
12v wireless relay kit on ebay....4 buttons. Mine has pinstripe lightwire on 1, motor glow led boca flasher on 2, ignition on 3, and 4 is reserved for mechanical iris for the head and tail light
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: July 17, 2012, 05:01:34 PM »
Interesting idea!
Offline aperry
« Reply #5 on: July 17, 2012, 07:00:05 PM »
Let me know when it supports turning the petcock on/off!
Aaron
CB750K3 with F1 frame/swingarm
« Reply #6 on: July 17, 2012, 07:50:37 PM »
Where is the fun? Kickstart forever!
Offline MattFreeman
  • What Have I Done?
« Reply #7 on: July 17, 2012, 08:13:50 PM »
Thanks for the link Dyrden. You 750 build is lookin sweet BTW. I may have to "borrow" a couple ideas from ya.
Offline Dyrden
« Reply #8 on: July 17, 2012, 09:46:36 PM »
If youre kinda handy with wiring its pretty simple.  Youll need to buy:
611t solid state relay
1 12v relay
RFID kit from ebay(I got 4 for like 25 bucks)
You swipe the keyfob.  Its sensed by the RFID receiver which then pulses 12v down a signal wire.  Its too weak to activate a standard relay.  You take this 12 positive pulse and send it into the 611t latching solid state relay.  This then depending on how you have it programmed can do lots of things.  It takes that pulsed weak signal and latches on.  I then take that 12v positive and use it to switch a heavy duty 12v relay which will then power whatever you want.  In my case it sends power to a fuse block and out to the rest of the bike.  In my case if you swipe a second time it will take that second pulse and latch off, cutting current to the relay which then opens and turns off the power to the fuse block.  Its pretty fun and costs almost nothing to do.
Offline skamagedon
« Reply #9 on: July 17, 2012, 09:47:56 PM »
i dont have wireless start, i turn it on with a button, saddle, kick with no key fumbling...
Offline Dyrden
« Reply #10 on: July 17, 2012, 09:50:56 PM »
This doesnt actually start the bike(though it could if you wired it that way).  Think of it as turning your key to the "on" position.  From there you can kick it, push it, hit your starter button or whatever floats your boat.
Offline the technological J
  • deliciouso!
« Reply #11 on: July 17, 2012, 10:08:02 PM »
http://www.ebay.com/itm/250310750026?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
 ive had this on the back burner for a while.. the only concern i have is that its always on standby and if you dont ride for a while  to charge the battery you might have a dead one
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Dyrden
« Reply #12 on: July 17, 2012, 10:11:25 PM »
That is true.  I wired a waterproof toggle in line with the RFID reader to keep the parasitic drain away from the battery when the bike is parked for a few weeks.  I should have mentioned that too. Thanks.  Master disconnect/storage switch.
Offline Dyrden
« Reply #13 on: July 17, 2012, 10:21:09 PM »
And so you guys can get a laugh:  I wanted to test fire it before I started wiring it for real.
Untitled by bailey_james62@ymail.com, on Flickr
Everything is working.
Offline MattFreeman
  • What Have I Done?
« Reply #14 on: July 18, 2012, 10:38:58 AM »
1 12v relay
Thanks a ton! How close do you have to swipe the fob to the receiver?
Offline Dyrden
« Reply #15 on: July 18, 2012, 01:22:36 PM »
Within 3 inches. Works through fiberglass tails....
