Author Topic: 78 550K Deal or no Deal?  (Read 4004 times)
Offline brewsky
« on: July 18, 2012, 11:09:23 AM »
Looking at picking up a 78 550K with 23k on it tomorrow for $400.00
Looks complete, (re-painted), orig 4/4, nice seat, orig air box,....... needs the usual, tires, chain, caliper rebuild, carbs cleaned.
Weeping at the head gasket a little, and some oil on top of the valve cover gasket.
Anything special to know about these?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Re: 78 550K Deal or no Deal?
« Reply #1 on: July 18, 2012, 11:11:09 AM »
TITLE?
Offline brewsky
« Reply #2 on: July 18, 2012, 01:33:33 PM »
Yes...clear title and is supposed to run..
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: July 18, 2012, 03:01:24 PM »
I dunno about where you are but around here "I'LL TAKE IT!!!"
I paid $900 for a non running 76 550. After looking around for months I thought I did OK.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline brewsky
« Reply #4 on: July 18, 2012, 03:37:28 PM »
Thanks for the info.....I'm not familiar with the 550's. The owner told me on the phone it was a 750, so that was what I was going to look at!
Needless to say, I'm not putting too much stock in what he says!
Did I read something about clutch/tranny weaknesses on these?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #5 on: July 18, 2012, 03:57:41 PM »
No.  They have improvements over the CB500.
The 78 carbs were finely tuned to the exhaust and induction.  Changing either means a carb jetting/adjustment endeavor, that most do not understand.
They are a very good bike in stock form.  Can be problematic and frustrating when modified.
The head gasket weep is pretty common.  I ignore it, wipe it off once a week as I don't believe it's work a tear down to fix two orings.
The cylinder cover (cam cover) has rubber "pucks", like filled orings, that harden with time/heat.  Not too difficult to fix that if you heed the shop manual warning about valve adjuster/valve stem interference (get that wrong and you bend several valves $).
A 35 year old bike will need all the electrical connections cleaned to keep it reliable.  Oxidation takes it's toll.
If all original beside paint and unmolested, an you can drive it, $400 ain't bad.
You'll have to be careful during the carb clean to keep from damaging the carb couplers.  Can't buy new ones anymore.  And using the older style couplers is a hodge-podge fit.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: July 18, 2012, 04:02:50 PM »
This is what TT is referring to before installing the cam cover:
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline brewsky
« Reply #7 on: July 18, 2012, 04:46:18 PM »
Thanks, TT, great info.!
I downloaded the manual and have been scanning thru it.....looks like you can do top end work without removing the motor?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #8 on: July 18, 2012, 04:52:12 PM »
Yes.
Offline brewsky
« Reply #9 on: July 18, 2012, 04:52:33 PM »
Thanks, I'll need to dig a little on this.....holding up the rockers?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #10 on: July 19, 2012, 01:47:58 PM »
rocker arms. if not held up out of the way they can bind on the top of the valves. When you go to tighten the cover down and turn your motor over the valve stems can bend or the valve guides can break.
its also a good idea to loosen your valve tappet adjusters all the way out too.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline brewsky
« Reply #11 on: July 19, 2012, 04:09:57 PM »
Got it......thanks again
Thanks again.
I picked it up today, and it is definitely a project.
Will post some pics in a bit......some a little amusing
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline brewsky
« Reply #12 on: July 20, 2012, 01:30:33 AM »
Some pics......
Note the bags mounted backwards, and the windshield crammed between the guages and handlebar!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline brewsky
« Reply #13 on: July 20, 2012, 01:48:59 AM »
Couple more.....
When I washed it off, I noticed the gas tank wouldnt drain under the lid.....the hose was threaded thru the rear tank mount rubber and therefore squeezed tight under the tank mount!
Windjammer came with the package which included leather lever tassels, spiked license plate frame, flag tire valve caps, and crash bars with one highway peg (the other must have been scraped off during the slide)
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #14 on: July 20, 2012, 06:33:06 AM »
That is a deal.  Seems like we always find something odd or stupid that the PO did to the bike.
Offline the technological J
  • deliciouso!
« Reply #15 on: July 20, 2012, 07:19:34 AM »
you got a great deal... and if you need to change the clutch its very simple
94 ST1100..Gone
72 750 K2 Stay tuned!
« Reply #16 on: July 20, 2012, 10:36:07 AM »
I know from experience that when those well drains plug up, the water fills above the cap vent hole and then enters the fuel supply.
Check for water in the gas and carbs.
I don't see much in the pictures that can't be corrected in a straightforward way.  Should be a nice bike with some careful TLC.
Offline brewsky
« Reply #17 on: July 20, 2012, 04:33:21 PM »
I will be flushing the tank, and the carbs are off and soaking now. (I am now convinced the 750 carb removal is a piece of cake!)
When I called the PO to schedule picking up the missing master cyl., he asked if I had started it up yet.....said it was running good the other day....RIGHT!. The #2 bowl and jets were completely sludged up and blocked, and the rest weren't a lot better. Turns out, according to him,  if you spray carb cleaner in the intake ........it's running good!
Had to search for damages due to the empty battery cell in the "new battery" which turned out to have a pin hole in the bottom. The top breather hose was butted up against the side of the battery, some wires and hoses were blackened and melted, and I thought there had been a fire........but now I think it was just acid melting stuff as it dripped out.
So, hopefully, some time with the pressure washer has prevented further damage.
« Last Edit: July 20, 2012, 04:34:57 PM by brewsky »
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline loaferoatan
  • Bar and Bike
    • Sundowner's Beach Bar
« Reply #18 on: July 20, 2012, 04:53:35 PM »
STEAL! Even if you have to put in $500 or so, it looks like it's going to be a pretty good little run around for under $1K.....CAFE IT!
Offline brewsky
« Reply #19 on: July 21, 2012, 02:07:20 AM »
I thought about the cafe route, but the seat is pretty comfy the way it is......will see later.
Now, just to get it running and see how the motor/tranny are.
I blasted the area of the acid leak pretty well, and there doesn't appear to be any major damage.
I hate to throw stuff away, so I'm trying to think of a good use for a good 10 volt battery (After the rest of the acid drains out of the bad cell)
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #20 on: July 21, 2012, 02:19:42 AM »
man!!!we never get deals like that here in australia,i wanna live in america,everythings cheap in america,hondas are free in america,i wanna live in america!
Offline brewsky
« Reply #21 on: July 21, 2012, 03:31:09 AM »
Actually, a while back, I did get a free Honda Shadow from a guy, who got it from a guy etc., with no title. It needed some work, and I really didn't have room for it, so I gave it to a friend, but decided to keep the original tool kit.
As he was on his way to pick it up, I opened the tool box to only to find the original title, endorsed to blank!
They always seen to be cheaper when you don't really want them to start with....I thought I was going to look at a twin to my 750, and the PO started at $1,300!
Now I really want a 305 Superhawk, but no deals around so far for that model!
I think I'm going to like the size of this 550.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #22 on: July 21, 2012, 04:06:13 AM »
youll love it,for an old tank they steer quite well and out accellerate most cars when the light goes green,theyve had cool factor since new and are a fun thing,they are mostly indestructible within reason and will tolerate a lot of abuse.
« Last Edit: July 21, 2012, 04:07:44 AM by dave500 »
  • deliciouso!
« Reply #23 on: July 21, 2012, 07:23:52 AM »
you should start a thread in the project shop..... i think theres a thread in the tips and tricks about rejuvenating an old battery
94 ST1100..Gone
Offline rboe
« Reply #24 on: July 21, 2012, 01:51:46 PM »
Looks like a real POS, so you should just save yourself some grief and ship it to me. I'll do you a favor and pay for shipping too.   ::)
Craig Vetter sells some parts for his old Vetter fairings if you are interested in using it. They really where the cat's meow back then.
1974 CB350F
2008 XR650L
2012 Griso SE
Past iron
1971 Suzuki TS125
1977 Honda CJ360T
1981 Kawasaki 550Ltd
2000 Moto Guzzi Quota
Offline grasscutter
  • Love the CB650.
« Reply #25 on: July 21, 2012, 02:02:36 PM »
Real nice!  Well worth the $400.  You done good.
**In one of the 1st pics...I think he mounted the bags backwards on purpose.  Bet if they went on the other way, they'd end up sitting on the exhaust.
Come on!  We're burning daylight!
Offline brewsky
« Reply #26 on: July 21, 2012, 04:01:38 PM »
OUCH!!!
Can't blame the PO on this flub-up, ..........snapped right off while wiping out the bowl........and I was being very carefull, I swear!
rboe,
I use a Vetter on my 750 in the winter....they are the best protection wise and airflow wise IMO, but a little on the noisy side.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline brewsky
« Reply #27 on: July 21, 2012, 04:36:19 PM »
Fingers crossed!
May be looking for another bowl soon!!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline brewsky
« Reply #28 on: July 25, 2012, 04:36:56 AM »
Well, TT mentioned oxidation, and sure nuff, there was some on the connectors.........but this was a surprise:
Wire brushing and WD 40 took care of it, but...
wonder why it picked that spot, none elsewhere?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline harisuluv
« Reply #29 on: July 25, 2012, 12:26:01 PM »
First off, you got an absolute steal on that bike.  I will take that all day everyday.
Second:  As far as the old battery, your use for it is this:  You can go to walmart and buy that same battery, but they will charge you $15 more if you don't bring back an old one.  Keep it, bring it with you when you get the new one.
Third:  I can help you with the spare bowl, cheap.  You can call me if you want as my number is in my thread, or just PM me.  If you don't mind one with the drain tube (coming OUT the bowl) with a little bend in it I'll hook you up for free as long as you pay for shipping.
Offline brewsky
« Reply #30 on: July 25, 2012, 03:11:52 PM »
PM sent....
Thanks for the offer and suggestions.
My carbs are PD46C and also have the outside drain tube.
BTW, you carb work looks great!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline harisuluv
« Reply #31 on: July 25, 2012, 03:58:58 PM »
Thanks!
The bent one I found leaked after testing so there must be damage to the drain tube but I found a good pd46c one.  I pmed you about which one you needed but I saw that you had listed that (left side or #1 or #2).  I'll PM you again later tonight.
Offline brewsky
« Reply #32 on: July 25, 2012, 04:35:52 PM »
Thanks again, Harisuluv, I really appreciate it!
From the looks of this, I should also be looking for some replacements for the corroded bowl drain screws! (the screws are "closed" in the pic).
If you keep a supply of them I would gladly to buy a set if you have enough to spare.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline harisuluv
« Reply #33 on: July 25, 2012, 04:43:10 PM »
Oooh I would but I don't think I have as many of those.  I do however know that "sirius consolidated inc" (you can google it) sells them.  They are not cheap though.  They have become sort of a specialty part.  It is a little hard to navigate the site as there are pages and pages that aren't really sorted out but they are there.  If you PM SOHCdigger he can probably help you out.
Offline brewsky
« Reply #34 on: July 25, 2012, 05:05:53 PM »
That's fine.....I have bought from sirius before, but may try digger.....thanks for the tip
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline brewsky
« Reply #35 on: July 30, 2012, 02:12:59 PM »
Got the bowl today!!...You are a gentleman and a scholar...not to mention doing fantastic carb work...it looks like brand new.
THANKS AGAIN!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
