Author Topic: Frame paint color  (Read 5396 times)
Offline Big_e78
Frame paint color
« on: July 22, 2012, 05:53:18 AM »
I want to repaint a few small items like my headlight bucket, footpeg mounts, kickstand etc. Anybody know of a close rattle can match? I'll probably repaint frame (and above mentioned items) one if these days, so I'm just looking for something to look decent until then.
Offline Big_e78
Frame paint color
« Reply #1 on: July 22, 2012, 05:53:37 AM »
On a 1976 cb750
Offline hondaface75
Re: Frame paint color
« Reply #2 on: July 22, 2012, 05:59:13 AM »
A generic gloss black wont do? Maybe a semi gloss if you dont want it 'too new' looking.
Offline Big_e78
Frame paint color
« Reply #3 on: July 22, 2012, 06:11:37 AM »
It very well may work. Is there not enough difference between different manufacturers black to make too much of a difference?
Offline lucky
« Reply #4 on: July 22, 2012, 08:54:06 AM »
There are differences.
If you use Duplicolor paint (NAPA stores) the two part clear in a special spray can is compatible with the duplicolor brand.
Offline 78whiteorbs
« Reply #5 on: July 22, 2012, 09:12:11 AM »
check this out:
http://forums.sohc4.net/index.php?topic=98350.0
also if you cant wait I have used VHT Semigloss black caliper paint from local autopart stores with great success. It is fuel and solvent resistant and holds up really well. Hope that helps- also it has been my experience that you should never consider "appliance epoxy" it is horrible horrible stuff stay far far away-
There I kicked the hornets nest now RUNNNNNNN!!!!!!!!!!!!!
Offline Really?
Frame paint color
« Reply #6 on: July 22, 2012, 02:32:22 PM »
I read that if you have it PC'd, it will need to be an 80% gloss. It may have been HM that said that.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Brantley
  • Drano
« Reply #7 on: July 22, 2012, 03:07:27 PM »
Eastwood Chassis Black is real close to stock. Duplicolor semi-gloss engine enamel is a good, cheaper alternative for frame parts. Duplicolor Universal Black looks good on headlight buckets, especially if you clear it.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #8 on: July 22, 2012, 03:28:39 PM »
Rust oleum gloss black, let dry overnight, rub with 0000 steel wool and then lightly oil with a rag.  This blends the touch up into the surrounding area.
Offline Big_e78
Frame paint color
« Reply #9 on: July 23, 2012, 03:42:59 AM »
When I was looking at vht caliper paint, I saw they had a chassis paint in satin and gloss. Would regular rustolem be chemical resistant? Center stand always cruded up with oil, don't want to repaint often.
Offline Magilla
  • My bike: 1976 CB750F
« Reply #10 on: July 23, 2012, 10:55:53 AM »
The best match I have found so far is satin black.  It is great for touch up areas and small parts.  Gloss will show all the imperfections in the metal.  Satin hides some of it.  I have a bunch of before and after pics I can share if you send me an e-mail request.  The pics are too high of resolution to post here.
Almost any brand satin spray paint will do just fine.
One note: if you doing frame touch up in a highly visible area you may have to use gloss.  Try a spot with satin first and then make your decision
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Online CycleRanger
  • No comment about being an
« Reply #11 on: July 23, 2012, 11:35:59 AM »
I use VHT gloss & satin Black. I've been happy with both. Imho, the VHT gloss is a very close match to the original black.
It's not too glossy.
« Last Edit: July 23, 2012, 01:03:52 PM by CycleRanger »
Offline phil71
« Reply #12 on: July 23, 2012, 12:01:33 PM »
Rust oleum sux.
Offline Seabass
Frame paint color
« Reply #13 on: July 23, 2012, 12:50:50 PM »
+1
76 cb550 F cafe, 74 cb550 k
Offline phil71
« Reply #14 on: July 23, 2012, 01:26:41 PM »
so does krylon, for that matter.. unless you're a graffiti artist
