Author Topic: Presta Valves VS Schrader valves.. bicycle stuff  (Read 3758 times)
« on: July 23, 2012, 10:34:42 AM »
 I got a MB with PRESTAs, am running street only and prefer Schraders..
 What are the pros and cons..mainly i dont like  it being harder to put air in them..
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Presta Valves VS Schrader valves.. bicycle stuff
« Reply #1 on: July 23, 2012, 10:51:00 AM »
Prestas were designed to allow a thinner width tire and tube to be used on road bikes, preferrably 700c series tires.
I have no idea why they would want to put them on MTB tires except to frustrate owners.
You can buy screw in adapters to inflate your prestas with normal schrader valve devices, it is a pain though.
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« Reply #2 on: July 23, 2012, 10:58:27 AM »
FYI: Most floor pumps have the adapters that will take both types built in. "Presta" has a metal valve all the way to the tube so the valve will endure more side to side stress at the rim entry point. Schrader valves are just rubber from the tire down.
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
« Reply #3 on: July 24, 2012, 08:44:43 AM »
 Its a Gary Fisher Joshua 3, I put road tires on.. as in cruiser, not skinny ones. It has prestas, I prefer the other for easier inflating.. not sure if I have to drill the rims/ The rims are Mavericks, rear is marked A SYM.
Offline Cheffish
« Reply #4 on: July 24, 2012, 08:56:40 AM »
Prestas do suck. I used the adapters for a while with no problems. They're cheap and easy to use. That way you can air up at gas stations and stuff. Mavics are good wheels. I suppose drilling them would be pretty safe if you wanna go that route
Offline luap
  • LAWL
« Reply #5 on: July 24, 2012, 09:47:29 PM »
Im pretty sure you can drill out the wheel to allow schrader valve also
paul
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
« Reply #6 on: July 24, 2012, 11:32:54 PM »
If you drill the rim for schrader valves it will cause issues going back to presta.
Since you are running on the street if you didnt know already, slicks will require less pedalling effort than most treaded tires. I had a hybrid (trek) that I put treaded tires on and the switch to slicks was amazing and the bike moved so much better...was commuting in Tucson...
Offline Vreihenmotor6
« Reply #7 on: July 25, 2012, 04:20:29 AM »
mainly issues arise when trying to run schrader on a super narrow (road) rim, since you have a mountain bike you're all set
just drill out your rim, 11/32 size bit I belive
« Reply #8 on: July 25, 2012, 06:26:57 AM »
The other issue is if you want to go back to a presta after you drill you would have to put some kind of a bushing or spacer to account for tha gap made by drilling. I say just use the screw on adapters.
« Reply #9 on: July 28, 2012, 08:47:27 AM »
 This may sound really dumb, but I am not used to bikes with gear clusters..where should I position chain, before rear wheel removal?.. smallest sprocket ?
Offline Cheffish
« Reply #10 on: July 28, 2012, 10:49:46 AM »
Yup. Then push the derailleur for some slack. And pull the wheel out
Offline veloracermike
« Reply #11 on: July 28, 2012, 11:13:24 AM »
Most high end MBs that don't run tubeless tires have presta valves.  It's not as described above for thinner tired road bikes. Prestas are ligte  Most co2 inflaters are designed for presta valves as well.
Offline Mtmooradian
« Reply #12 on: July 28, 2012, 11:42:42 AM »
Main reason is strength.... Smaller hole makes for stronger rim.
« Reply #13 on: July 28, 2012, 12:04:01 PM »
Most high end MBs that don't run tubeless tires have presta valves.  It's not as described above for thinner tired road bikes. Prestas are ligter  Most co2 inflaters are designed for presta valves as well.
Offline faux fiddy
  • bike in a box
« Reply #14 on: July 28, 2012, 12:38:19 PM »
When I rode skinny tire bikes I thought Presta was the coolest thing, and they did make a frame pump that could get you back to town if you flatted.
Now I like shrader,  finding air is more convienient without  keeping track of adapters or carrying a pump.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #15 on: August 01, 2012, 08:26:20 AM »
 I dont undersrtand, this on my gary Fisher Joshua 3;
 The riont wheel appears to be straight laced, the rear is cross 3. Is not the straight lace wheel the WEAKest design, espescially for off-road?
« Reply #16 on: August 01, 2012, 09:08:25 AM »
Probably, but the front tire on a bicycle does not support as much weight and force as the rear does.
« Reply #17 on: August 01, 2012, 09:16:49 AM »
Couple of reasons, straight laced are lighter and more aero, and like was just mentioned the front doesn't support as much weight.  A proper straight laced wheel with the right tension is very tough though.
Offline Mtmooradian
« Reply #18 on: August 01, 2012, 11:27:33 AM »
On a mt bike a standard 3cross front is the best, with the right double butted spokes you can get the weight down... Straight laced is fine for road, mtb its pushing it. But it also depends on the type of riding. My race wheels are about 1350grams ....
« Reply #19 on: August 20, 2012, 01:56:49 PM »
there were a few companies that liked to build wheels like this for mountain bikes around the 2000s, if it was a shimano hub, being laced like that voided the warranty, but the trek family of brands had a supplemental warranty that would supersede the shimano one, I  always found that funny. now that disc brakes are the brake of choice for mountain bikes, the radial front wheels have gone mostly away
Offline Mtmooradian
« Reply #20 on: August 20, 2012, 08:08:13 PM »
Specialized did it with a bunch of there wheels
Offline faux fiddy
  • bike in a box
« Reply #21 on: August 20, 2012, 09:44:14 PM »
Yeah, but if someone thinks it's cool it doesn't matter.
I  have to go check mine sometime.  I think my high flange hubs were all three cross and low flange were four.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #22 on: October 01, 2012, 01:26:58 AM »
 My Bridgestone MB5 has them as do all my Raleighs. I never give it much thought as to it "being a pain" to inflate them.... until you loose all your adapters ;-( They do look cool, they are smaller and people say "what the hell is that?" Can't say if they leak more or less but I have had rims drilled for Schrader valves and I found rubber bushes somewhere to semi-restore them back to the way they came. They don't stay put too well though.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
