I feel sorry for you that it cost all that money.
The idle jets will need to be #42's
You could change main jets all day long with no effect on your problem.
The problem is the transition from idle to 1/4 throttle.
You also need to experiment with the mixture screws. 1/8 turn cam make a difference on these carbs.
Pods and open drag pipes.
WHICH CARBS? 7A or 657A'S
WERE not where.
EXAMPLE: Idle jets were 40 mm.
QUOTE:
"i broke down took my carbs in to have gone throughcost a arm and a leg. did some research on pods and such tiold the guy to put in 125 main jets he did idle jets where 40 set the needle at 4 well it runs even worse than it did before.i was running pods took them off and put on the old santee breadbox breather.what it does is idle then give it gas it kinda backfires and dies.it runs fine at idle until you give it throttle. i'm taking them back tomorrow what should jets should i have put in instead of the 125 this engine has the 836 kit in it open drag pipes
SHOULD BE:
I
broke down
and took my carbs in to have
them gone through
.It cost a
n arm and a leg.
I did some research on pods and such
. I
told the guy to put in 125 main jets
which he did
. The idle jets
were # 40 mm's. I set the needle at
4th groove from the top. Well it runs even worse than it did before.
I was running pods took them off and put on the old
Santee breadbox breather.
Now what it does is idle then
I give it gas it kinda backfires and dies.
It runs fine at idle until you give it throttle. i'm taking them back tomorrow
. What
main jets should
I have put in instead of the
#125 mm's? This engine has the 836 kit in it open drag pipes
