Author Topic: can you shim a fork braket?  (Read 855 times)
Offline rab1dwolf
« on: June 22, 2006, 09:19:43 PM »
just got a new triple tree in the mail and the brakets to hold the forks in at 1/8" too big.
so i was wondering if i could shim the forks with something to fill that gap so i could use this tree.
and if so whay would i use? metal? rubber?
1982 cb650sc nighthawk.  the work never stops.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: can you shim a fork braket?
« Reply #1 on: June 22, 2006, 09:32:12 PM »
How many mm?  Take it as a sign to get beefier front forks - I wouldn't muck around with shimming these - wee bit risky.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline rab1dwolf
« Reply #2 on: June 22, 2006, 09:41:31 PM »
so of a...this whole project of trying to swap out my handlebars has been a friggin nightmare
edit: space is about 5mm with the bracket as tight as it goes....
« Last Edit: June 22, 2006, 09:53:15 PM by rab1dwolf »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: June 22, 2006, 10:03:43 PM »
I've heard somewhere here on an old thread that tin foil might be the answer :o :o
Offline rab1dwolf
« Reply #4 on: June 22, 2006, 10:13:05 PM »
i was thinking if i took a small peice of say..aluminum or such and used some jb weld to affix it to the inside of the clamp that it should work?
or is this just a horrible suicide line of thinking and should give it up wanting new bars....
« Last Edit: June 22, 2006, 10:54:05 PM by rab1dwolf »
