Author Topic: Let it all hang out,tell us how you really feel and what pisses you off.  (Read 1448287 times)
Offline petercb750
Re: Let it all hang out,tell us how you really feel and what pisses you off.
« Reply #4500 on: January 05, 2014, 02:54:59 AM »
Dave - I got them cheap  ;D
But the 1100 does seem a bit 'sharper'...but that could just be my imagination. I won't get around to changing the 750 ones back until next Saturday, so see what happens.
TB - they are at .2mm...you think that is ok?
Pete, do you mean 1.2mm, if so that is too wide for the standard ignition (0.2mm wouldn't run), they need to be about .8mm.  If you do regap them be very careful to not knock the tip off the centre electrode.
oops, hang on, maybe I was looking at the imperial feeler gauge...maybe it was .2inches.....which would put it at about .6mm....
Yeh obviously .2mm is sfa. My bad.
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Offline trueblue
« Reply #4501 on: January 05, 2014, 03:09:31 AM »
Just double check the gaps Pete, if we're talking imperial you want to be about 0.031" or 0.8mm in metric ;)
Dave, it's not so much a miss as a stutter or sneeze.  Just a slight unevenness at idle.  All VN's-VR's did it, the only fix I have found was platinum plugs.  I used to own a VP myself and it drove me nuts, never affected the way it ran, it would still do 210kph in 3rd.  It just sounded horrible, like all the early commodore V6's.
1979 CB650Z
Offline petercb750
« Reply #4502 on: January 05, 2014, 03:22:16 AM »
Oh ffs.....I just checked my feeler gauges....it would appear that the .2, .25 and .3mm gauges were stuck together, so I was measuring .75, which is near enough to correct.
This is why I am not a mechanic  :-[
Now I'm pissed off cos I'm so embarrassed.
« Reply #4503 on: January 05, 2014, 03:24:01 AM »
you must have bad fuel your way or something?the pack under the coils goes off,the coils check fine but fire #$%*ty,its an imbalance hooked into the ecu,these are old cars now and this stuff is just turning up now,this late model crap pisses me off,you have to swap expensive parts to be sure,like all of the electronics,then youll still be wrong?having the correct gap helps.
Offline trueblue
« Reply #4504 on: January 05, 2014, 03:38:18 AM »
Don't worry about it Pete, I picked up a set of feeler guages last week to set some valves at work.  After setting them I thought they felt a little loose, checked the guages again and realised I was looking at the inch markings, not the metric marks. :-[
Dunno what it is Dave, all I know is damn near every pre ecotec commodore I have looked at since I started my trade has the same stutter. ???
1979 CB650Z
« Reply #4505 on: January 05, 2014, 03:46:39 AM »
its an off idle falter,the thottle body and its sensor need cleaning,the fine wire needs cleaning,the vac signal gets delayed,they still fly for what they are,thats why these are the weapon of choice for bogan donut hoons,they dont break either,i dont hate these engines,i hate the electronics on them road side!they piss me off!
Offline krusty
« Reply #4506 on: January 05, 2014, 04:24:47 PM »
Opened a new pack of bacon to have some with my eggs for brekky and noticed something unusual on the packet "Animal Welfare Friendly".  I'll bet the pig would have been pissed if he saw that.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #4507 on: January 05, 2014, 05:47:06 PM »
What does that mean?   They slaughtered the pig in a friendly way?!  That would piss me off.
Offline petercb750
« Reply #4508 on: January 05, 2014, 06:29:38 PM »
Not as much as it would have pissed the pig off.
Offline trueblue
« Reply #4509 on: January 06, 2014, 03:48:32 AM »
No falter Dave, engines run fine.  Plenty of power and smooth delivery from idle to redline.  Just every couple of seconds at idle they make a sound like a slight miss, but they aren't missing.   Just sounds horrible to someone who likes a smooth running engine.  Most people don't notice it ;)
1979 CB650Z
« Reply #4510 on: January 06, 2014, 11:09:49 PM »
I won a set of NGK Iridium plugs for a "Letter of the Month" to Spannerman at AMCT a few years ago Pete, and had the same experience as you.
An expert here told me that Iridium plugs don't like the stock CB750 resistor plug caps, so I changed the leads for Bosch 8mm silicon leads and caps (Dyna 3 Ohm coils) and it made no fcuking difference, so they're still here, sitting on a shelf.
If your plugs are fouling due to a rich mixture (which you'll get if you set your carbs up as per the Honda manual, but with modern fuel) change them from D8's to D7's, and you won't have a problem.
Lastly, you need me to teach you about revenge. If someone wrongs you like that jerk did, follow him home by all means, but don't abuse him, ride past and go back at 3am and burn his fcuking house down, with him and his family inside.
If you can wait a few months, even better, with his attitude he'll have pissed off other folks in the interim, and he'll probably have forgotten about your incident. If he survives........... ;D
Offline petercb750
« Reply #4511 on: January 07, 2014, 02:22:02 AM »
haha Terry, I did think of something like that....I had some old brake fluid here that would suit his toffy top of the range VW 4WD.........
The old 8's I had in the 750 before putting in the iridiums, were fairly well ok most of the time, just now and then I'd get a bit of fouling on cold starts (ie with choke), but generally ok. I mistakenly thought the iridiums might fix that..... ::)
I've just bought a set of 8's which will go in on Saturday, see how it goes.
Cheers  :D
Offline petercb750
« Reply #4512 on: January 07, 2014, 02:23:39 AM »
Anybody want to buy a set of 4 iridium plugs.....almost new......??  ::) ;D
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #4513 on: January 07, 2014, 10:21:39 AM »
PETA - People Eating Tasty Animals
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #4514 on: January 07, 2014, 12:56:10 PM »
Put them in your pocket and throw 'em at tailgaters mate, that's all they're good for.......... ;D
Offline kghost
« Reply #4515 on: January 08, 2014, 08:51:28 PM »
Lemme tell you what pisses me off.......
I was sitting at my computer deeply concentrating on studying Aircraft systems.....
While listening to music to block out the distractions around here.
I completely forgot the time and that Dave500 was coming by.....
So...poor Dave sits downstairs Hollering...rings my phone....knocks....
I hear none of this and Dave leaves....but not before leaving the 6 pack of beer he brought on my workbench.....
Don't I feel like a tool? You bet
Stranger in a strange land
« Reply #4516 on: January 08, 2014, 08:59:33 PM »
Well look on the bright side Tim, at least you get to drink all 6 beers! (sorry Dave......) ;D
« Reply #4517 on: January 08, 2014, 10:57:07 PM »
oh well,beer happens?
Offline brentjgordon
« Reply #4518 on: January 08, 2014, 11:56:09 PM »
well i dont get pissed off too often but when i do its usully because of the douche that overtightened the oil filter (which then must be removed by three garden gnomes using tiny jack hammers), oh and yeah that douche? me. one thing i do find curious is the amount of people that own m/c's  .that have never crashed, knocked over, backed into or otherwise done any damage to their used motorcycle....i have personally crashed no fewer that 9 motorcycles since i started riding at age 10....im now 50.im sure there are some i just dont remember .  one unfortunate 1978 honda 750 k was brutalized 3 times in traffic  finally resulting in that  machines retirement. dont even want to talk about my first h2 750 which i called "scar tissue". point is there is no shame in paying your riding dues with your bikes skin and bones but there is no way that "previous owner" could have racked up so much damage . if ya want blame me my name is brent ...im the previous ownrer! thanks for listening :o
Offline mick7504
« Reply #4519 on: January 09, 2014, 12:26:33 AM »
G'day Brent
Good that you're pissed off mate because the rules are that you're not allowed here unless ya pissed off.  ;D
Anyway mate, if I crashed my bike 9 times I'd be pissed right fcuken off too.    ;D
Or pissed.  ;D
« Last Edit: January 09, 2014, 12:31:30 AM by mick7504 »
If I was you
I'd be worried about me.
Offline petercb750
« Reply #4520 on: January 09, 2014, 01:53:41 AM »
G'day Brent
AND pissed.  ;D
fixed that for ya mate. ;D
Offline mick7504
« Reply #4521 on: January 09, 2014, 02:03:33 AM »
G'day Brent
AND pissed.  ;D
Thanks buddy.  ;D
Very true.   ;D
If I was you
« Reply #4522 on: January 09, 2014, 03:49:01 AM »
G'Day Brent, don't be too hard on yourself mate, I bought my first CB750 new in 1978 (superseded F0) and the poor (but fugly) thing spent more time on it's sides than it did on it's tyres, I reckon?
The "Last Straw" was when I hit a gutter @ 90 MPH (drunk of course) went over a large bush, and hit a "Give Way" (Yield) sign pole 4 feet above the ground and bent it at right angles as it slid across the road on it's alternator cover. I managed to break all my ribs on my left side, but was so whacked that I didn't notice, so I pulled the bike back onto it's wheels and pushed it two miles home.
I repaired it myself (new tank, alternator cover, points cover, handlebars, fender, muffler etc) and traded it in on a car, I'd only had it for 10 months and had crashed it heavily at least 3 times that I can remember, and one of my mates dropped it as well, so whoever bought a yellow F rego No LP-942 in December 1978, I feel sorry for you, and by the way, I never had the first service done either, so it might need an oil change? Oops......... Cheers, Terry. ;D
Offline motocyconomad
« Reply #4523 on: January 09, 2014, 04:45:24 AM »
taxes ....#$%* them and anyone that says we need them. schools ,firefighters,roads and cops all will get done without a #$%*ing tax scam.
« Reply #4524 on: January 09, 2014, 06:22:38 AM »
Are ya pissed off Moto??
Pissed off at roads?  I'm pissed off at the road repairs around here!   They dug up the roads for utility work and did lousy patch job when they were done. That pisses me off!
